How do I update SRP541w firmware?
greatmatter
I just bought the SRP541, and it has the old firmware. I downloaded the new firmware, yet I cannot figure out how to install it. Any pointers? Thanks!
Andrew Hickman
Hi Adam,
Make sure that you log in with admin/admin, not cisco/cisco.  You will see the upgrade option under the Admin tab.
Cheers
Andy
Andrew Hickman
Hi Adam,
Cheers
Andy
You, sir, are awesome--thank you very much.
My pleasure :-)
As you explore the features, take a look at the following link for further documentation.  Admin Guide can be found in Support Documentation links on the righthand side of this page.
www.cisco.com/go/srp500
Cheers
Andy
