How to set a VPN IpSec Tunnel GW to GW tunnel between RV110W and RV042
esagastume002
I am using a Cisco RV110W (Firmware 1.2.09) in a branch and I would like to create a VPN Tunnel to another site that has a Cisco RV042 (firmware
v4.2.1.02)
What would be the correct Configuration??
the current configuration I am using is
in the RV042 i am using
Check Enable
Local Group Setup
Local Security Gateway Type : IP Only
IP Address : RV042 Pulbic IP address
Local Security Group Type : Subnet
IP Address : 192.168.20.0
Subnet Mask : 255.255.255.0
Remote Group Setup
Remote Security Gateway Type : IP Only
IP Address :  RV110W Pulbic IP address
Remote Security Group Type : Subnet
IP Address : 192.168.30.0
IPSec Setup
Keying Mode : IKE with Preshared Key
Phase 1 DH Group :  Group 2 - 1024 bit
Phase 1 Encryption : AES-128
Phase 1 Authentication : SHA1
Phase 1 SA Life Time : 28800 seconds
Perfect Forward Secrecy :  Check
Phase 2 DH Group : Group 2 - 1024 bit
Phase 2 Encryption : AES-128
Phase 2 Authentication : SHA1
Phase 2 SA Life Time : 3600 seconds
Preshared Key :  XXXXXXXXX (same as RV110W)
Advanced
Uncheck     Aggressive Mode
Uncheck     Compress (Support IP Payload Compression Protocol(IPComp))
Uncheck     Keep-Alive
Check         AH Hash Algorithm  SHA1
Uncheck     NetBIOS Broadcast
Uncheck     NAT Traversal
Check         Dead Peer Detection Interval 10 secs
Uncheck     Tunnel Backup :
Uncheck     Split DNS :
In the RV110W  my configuration is
IKE Policy Table
Add / Edit IKE Policy Configuration
Policy Name:  XXXX
Exchange Mode: Main
IKE SA Parameters
Encryption Algorithm: AES-128
Authentication Algorithm: SHA-1
Pre-Shared Key: XXXXXXXXX (same as RV042)
Diffie-Hellman (DH) Group: Group2 (1024 bit)
SA-Lifetime: 3600 Seconds
Dead Peer Detection: Check Enable
DPD Delay: 10
DPD Timeout: 30
VPN Policy Table
Add / Edit VPN Policy Configuration
Policy Name: XXXX
Policy Type: AutoPolicy
Remote Endpoint: IP Address
(the RV042 IP address)
Local Traffic Selection
Local IP: Subnet
IP Address: 192.168.30.0
Subnet Mask: 255.255.255.0
Remote Traffic Selection
Remote IP: Subnet
IP Address: 192.168.20.0
Manual Policy Parameters  (disable, is in Auto Mode)
SPI-Incoming: 0x
SPI-Outcoming: 0x
Encryption Algorithm: 3DES
Key-In:
Key-Out:
Integrity Algorithm: SHA-1
Key-In:
Key-Out:
Auto Policy Parameters
SA-Lifetime: 28800 seconds
PFS Key Group: Checked Enable
     DH Group 2 (1024 bit)
Select IKE Policy:  XXXX  (the same in previews configuration)
Can some one please tell me what I am doing wrong
Hello Mr. Sagastum,
My name is Diego and I am part of the Small  business Support community. I have seen your  post and would like to help you with information  that might be helpful on your case. On the next link you would find an example of VPN tunnel configuration, step by step. You could find this and more information about our cisco small business products on the guide me section.
http://sbkb.cisco.com/CiscoSB/ukp.aspx?vw=1&docid=b88c949b4d35460fac902f16ee08e44c_Configuration_of_Backup_Tunnel_on_RV016__RV042__and_RV082.xml&pid=4&fcid=&fpid=&slnid=4
If this answer was satisfactory for you, please mark the question as Answered.
Diego Rodriguez
Cisco network engineer
Thank you
Thanks Diego for your answer
I check the link, and is great to get started on VPN
Actually I have a couple VPN set in my RV042 Router and they work fine
My problem is matching and pairing the RV110W with RV042, to make the VPN Tunnel working between this two aplicances, specially because the configuration available in the RV110W is very limited. and the configuration setup page is very different from the RV042
pmagliola
Roberto:
I had the exact same configuration you mentioned and couldn´t get it running either.
I made it work only by disabling "Aggresive mode" on the rv042.
Good luck!
Pablo Magliola
