11-15-2010 01:37 PM
I have an ASA assigning 10.10.100.0/24 addresses to my LAN. The router of course gets it's IP in the same subnet. I need wireless devises to be able to access the LAN.
How to?
Thanks! Brian
Solved! Go to Solution.
11-17-2010 08:07 AM
If I understand you correctly, the question you're asking boils down to "how do I use my WRVS4400N as an access point?" For most low-end wireless routers, the answer is, disable the DHCP server on the wireless router and connect the wireless router to the rest of your LAN via it's LAN port [not its WAN port]. As most wireless routers bridge their WLAN and LAN this should work fine. If the WRVS4400N doesn't bridge the LAN and WLAN, it won't work.
11-19-2010 11:14 AM
I agree with openipitd, give the wrvs4400n's lan a management ip address, turn off the dhcp server and plug lan into lan. The router function will not be utilized and the router will basically be an access point.
11-17-2010 08:07 AM
11-19-2010 11:14 AM
11-23-2010 01:15 PM
That did the trick. I was not plugging it into the LAN. DUH!
