RV-340W Wireless Password Resetting
ac8200
I have a problem where the wireless password seems to expire every day (don't know if it is exactly 24 hours), but a wireless password that works one day fails the next day on multiple Window 10 computers.
I have looked in the settings for any timeouts that need to be set and I cannot find any.   The only password expiry setting I see is the one for the router itself.   It is currently set not to expire.
Am I missing something in the settings or is there another possible reason for why a windows client can hook up one day and not the next ?
balaji.bandi
I do not see any settings like this in the document, which has any password expiry
https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/smb5622-configure-basic-wireless-settings-on-the-rv340w-router.html
how are you resolving the issue, by reset password ?
when you have issue worth look at the Logs on the device also run some wireshark on PC see what is wrong ?
BB
Thanks for the information.   Like you I didn't see anything in the documentation.
Yes, we reset the password, but that is a pain.    I will check the logs and see if anything jumps out at me.  I hope to avoid wireshark, but if I cannot any suggestions on what to look for beyond some detail in the packets ?
Alex
Since this was specific to your environment, not that i aware any one reported. good to have more debug logs, which enable us to understand the where the issue resides.
BB
