RV320 - Multicast settings - IPTV
morpheanuk
HI all,
Wonder if you might be able to help me figure this issue out. I chose the Cisco RV320 since it is Dual WAN, SPI firewall and generally a pretty solid product.
However I am recently facing an issue where I cannot configure: IGMP, IGMP Snooping, or being able to play any multicast streams.
Does anyone know if the rv320 can be configured to do this? at the moment I cannot find any setting anywhere to do with IGMP, and I am amazed that a professional router like this has no option for it.
Thanks in advance.
gariasca
There are no IGMP settings available on the RV320 in this unit you only have Multicast Pass Through Enable/Disable checkbox which will either make the router pass through the multicast packets or not.
Cheers
-Gerald
Where in the menuing system is the setting for Multicast Passthrough?
Not sure if it's exactly the same on the 320, but the 325 it's under Firewall->General->Multicast Pass Through
