Hi,I have 5 peoples lines on my phone and wanted to know if there is a way to SCREEN the call as i only want to answer it if it is an interoffice call. Thanks
Hello,I have set up my IP-phone. Now I can make phone calls and also I receive incoming calls. However there is one problem with incoming calls:After some minutes after the last outgoing call my phone is not reachable for incoming calls anymore. ...
view more
May I ask how to set PMF as REQUIRED in version firmware version 1.1.2.4 of WAP150? Guide published in 2019-08-20 shows PMF but there's no newer guide that matches the release of 1.1.2.4 in 2020 on showing how to set PMF to required.
How do I setup PC port spanning in the small business configuration web-based utility ? I am trying to use Wireshark by connecting the computer to the PC port on the SPA504g. However, I am not seeing the SIP or RTP packets. I can't find the "Span to PC Po...
view more
