Alberto Montilla
This information has been translated from http://blog.voz-ip.com/2011/tlssrtp-en-asterisk-1-8/
Thanks to Gorka Gorrotxategi from Irontec (Spain), for his work on this setup
Here  we come with a short post about how to configure one of the new Asterisk 1.8 features: Secure Communications via TLS and  SRTP, providing ciphering and security.
These tests have been performed with Cisco SPA5XX IP Phones, and requires a small patch on Asterisk code (we will see below the reasons for the patch). It also work with other terminals such as Snom and Blink softphone.
The configuration will be explained briefly, as it explained in other places of the web.
[toc:faq]
Compile libSRTP library for Asterisk to support SRTP
Following are the commands required to compile the library
wget http://srtp.sourceforge.net/srtp-1.4.2.tgz
tar zxvf srtp-1.4.2.tgz
cd srtp/
CFLAGS="-Wall -O4 -fexpensive-optimizations -funroll-loops -fPIC" ./configure
make && make install
Download and compile Asterisk (we used 1.8.2.3)
Following are the commands required to download and compile Asterisk
svn co http://svn.asterisk.org/svn/asterisk/tags/1.8.2.3/ asterisk18
cd asterisk18
./configure
make menuselect (ensure that res_srtp is active on 'Resource Modules')
Apply patch
We now need to apply the patch mentioned before, why? The SPA5XX sends two lines with the crypto attribute:
a=crypto:1 AES_CM_128_HMAC_SHA1_32 inline:Ud154Hz42jLai6YI7RBcKtctTHBzIKjiHM6nGD36.
a=crypto:2 AES_CM_128_HMAC_SHA1_80 inline:Ud154Hz42jLai6YI7RBcKtctTHBzIKjiHM6nGD36.
Asterisk default code is not able to negotiate which method (AES_32 or AES_80) is going to be used for the ciphering. In fact, it always select the first one, and this is AES_32. Here the issue, Asterisk is able to handle both types, both offers only one of them, AES_80. The Asterisk patch force to signal the AES_32 method, to avoid audio issues due to different ciphering method used on each path. When this happens there is a non-ending warning message (30 per sec) on the CLI:
WARNING[25205]: res_srtp.c:338 ast_srtp_unprotect: SRTP unprotect: authentication failure
More Info is available on the Digium's bug tracker
We can see this problem clear on SIP traces (first INVITE from SPA then INVITE from Asterisk to destination):
INVITE sip:200@10.10.0.165 SIP/2.0.
To: "200" .
m=audio 16890 RTP/SAVP 8 0 9 18.
a=crypto:1 AES_CM_128_HMAC_SHA1_32 inline:hE+4XPMbPaF9/XEgIek7rUJiqoTEpLGZ1YXNiJhS.
a=crypto:2 AES_CM_128_HMAC_SHA1_80 inline:hE+4XPMbPaF9/XEgIek7rUJiqoTEpLGZ1YXNiJhS.
INVITE sip:200@10.10.0.177:5063 SIP/2.0.
To: .
Contact: .
User-Agent: Asterisk PBX 1.8.2.3.
Remote-Party-ID: "100" ;party=calling;privacy=off;screen=no.
m=audio 12202 RTP/SAVP 8.
a=crypto:1 AES_CM_128_HMAC_SHA1_80 inline:5uWtfxfK0vE90lTrgLTr83bRWTL2nCEFJ6NlXWjq.
The patch is really simple:
--- channels/sip/sdp_crypto.c 2010-06-08 07:29:08.708826000 +0200
+++ channels/sip/sdp_crypto.c 2011-02-24 17:37:00.514711568 +0100
@@ -287,7 +287,8 @@
  int sdp_crypto_offer(struct sdp_crypto *p)
  char crypto_buf[128];
- const char *crypto_suite = "AES_CM_128_HMAC_SHA1_80"; /* Crypto offer */
+ //const char *crypto_suite = "AES_CM_128_HMAC_SHA1_80"; /* Crypto offer */
+ const char *crypto_suite = "AES_CM_128_HMAC_SHA1_32"; /* Crypto offer */
  if (p->a_crypto) {
     ast_free(p->a_crypto);
Then apply the patch (we named it sdp_crypto.patch):
patch -p0 < sdp_crypto.patch
(assuming we are on /usr/src/asterisk18 and have the patch on same folder)
Asterisk is patched!!! Now we can compile and install:
TLS and SRTP Configuration for Asterisk and SPA5XX
TLS configuration
  • First we generate a public key and a private key, merge it in a single file and save it in a known folder as this is for testing. There are way more elegant and better ways of doing it (readme).
openssl genrsa 1024 > host.key
openssl req -new -x509 -nodes -sha1 -days 365 -key host.key > host.cert
cat host.cert host.key > asterisk.pem
mv asterisk.pem /etc/asterisk/keys/
  • Configure sip.conf in order to utilize TLS
tlsenable=yes
tlsbindaddr=0.0.0.0
tlscertfile=/etc/asterisk/keys/asterisk.pem
  • Configure peers to work on TLS. Both realtime as raw in sip.conf you need to add:
transport=tls (UDP is used by default)
  • Configure the SPA5XX to use TLS (remember to press Submit all button)
After this configuration, we have secure signaling using TLS between Asterisk and the IP Phones. If you capture port 5061, you will see ciphered text.
....J...F..Mg|.L^
...E}.....A...d.|.~...... l..i9.j,..q"..............&./....5................0..~0...................0...*.H........0..1.0...U....ES1.0...U....Vizcaya1.0...U....Erandio1.0...U.
..Irontec1.0...U....VozIP1.0...U....Irontec1 0...*.H........vozip@irontec.com0...110215125446Z..210212125446Z0..1.0...U....ES1.0...U....Vizcaya1.0...U....Erandio1.0...U.
..Irontec1.0...U....VozIP1.0...U....Irontec1 0...*.H........vozip@irontec.com0..0...*.H............0........>.S.51...bND.J..Q..O.).-t.."~x..g&^t....E.*..@..n.jF...v.t.<....Zf...%Y.......[...[....HE.e....9..8...qc..|(...P.....*.c4>.V..........0..0...U.........En?.0.%.^......
.0....U.#...0.......En?.0.%.^......
..Irontec1.0...U....VozIP1.0...U....Irontec1 0...*.H........vozip@irontec.com...........0...U....0....0...*.H............T.-F....R..2%.....T......=9.ye.z..6.0............i...O;.../s..e.........S.6.31......!iT......N....]........>XNt....Z...MHKH3...K.........
SRTP Configuration
  • To configure SRTP add the ‘encryption’ directive in all peers (both realtime or sip.conf)
encryption=yes;
  • Configure SPA5XX. Note version should be 7.4.3 or later (note that configuration applies to ALL lines).
    • [SIP] SRTP Method: s-descriptor
    • [PHONE] Secure Call Serv: Yes
    • [USER] Secure Call Serv: Yes
Voila! SRTP is configured!
Note: There is no optional SRTP mode in Asterisk, i.e. if encryption is active on peer, it will not accept non-ciphered audio and viceversa. On the IP phones, however, it is possible to have unsecure calls if the other peer does not support SRTP, i.e. incoming calls may work, but not outgoing calls. This is an Asterisk limitation (Snom supports also the “optional”mode on SRTP sending two m=audio attributes, but Asterisk does not know how to handle those descriptors).
Testing the configuration
The easiest test is to capture network traffic and verify with WireShark or similar software to check if signaling or RTP is clear text/audio or ciphered.
Known issues
In our tests, we found an intermittent Warning on Asterisk CLI, but it does not seems to affect operation
We are still debugging this issue to understand what is causing it.
<end>
Adolfo Arizpe
I have tried it step by step, at the moment I try to patch, I get a message:
root@pbx:/usr/src/asterisk18 $ patch -p0 < sdp_crypto.patch
patching file channels/sip/sdp_crypto.c
patch: **** malformed patch at line 4: int sdp_crypto_offer(struct sdp_crypto *p)
I am running Freepbx with Asterisk 1.8.28.0
Dan Lukes
The patch file must be created carefully to follow 'patch' program requirements. It seems you failed to do it properly.
If you are unable to prepare correct patch, then you can patch sources manually, according the instructions from patch file.
So, search for sdp_crypto_offer function in channels/sip/sdp_crypto.c source file, search for
const char *crypto_suite = "AES_CM_128_HMAC_SHA1_80"; /* Crypto offer */ line within it and replace the AES_CM_128_HMAC_SHA1_80 constant with AES_CM_128_HMAC_SHA1_32
That it is.
Adolfo Arizpe
Thank you so much for your quick reply. I'm sorry to keep asking such questions, but I can't find such line.
This is what the function looks like in my sdp_crypto.c:
        if (ast_strlen_zero(p->suite)) {
                /* Default crypto offer */
                strcpy(p->suite, "AES_CM_128_HMAC_SHA1_32");
        /* Rebuild the crypto line */
        if (p->a_crypto) {
        if (ast_asprintf(&p->a_crypto, "a=crypto:%s %s inline:%s\r\n",
                         p->tag ? p->tag : "1", p->suite, p->local_key64) == -1) {
                        ast_log(LOG_ERROR, "Could not allocate memory for crypto line\n");
                return -1;
        ast_log(LOG_DEBUG, "Crypto line: %s", p->a_crypto);
        return 0;
const char *sdp_crypto_attrib(struct sdp_crypto *p)
        return p->a_crypto;
Dan Lukes
The patch has been created for Asterisk 1.8.2.3
It seems that required change is already done in your's 1.8.28 version.
