Two inbound scenarios can exist in a SPA9000 environment.
i. Calls come in via a SIP trunk that the SPA9000 is registered to
ii. Calls come in via a PSTN trunk on a SPA400 that the SPA9000 is registered to
An office may have some general DIDs and some private DIDs.
General DIDs should ring the AA or a configured hunt group while private DIDs should ring the desk of the owner of the private DID.
Configure Inbound Call Routing as Follows:
- Identify the called number to be routed and document it, example 3335551212
- Identify the target of the called number, example extension 35
- Identify the Line tab of the SPA9000 that is registered to the SIP trunk/SPA400 3
- SPA400: Identify the port that the line carrying 3335551212 is attached to, example 2
SIP trunk DID Inbound Call Routing:
- Use the SPA9000's web-ui to change Voice tab > Line N tab > Contact List: 3335551212:35| [original contact list info]
- Scroll down and click Submit All Changes
PSTN trunk DID Inbound Call Routing:
- Use the SPA400's web-ui to change Setup tab > Basic Setup > Port ID > Port ID 2: 3335551212
[You replace FXO_Port_ID_2 with the DID associated with the port] - Scroll down and click Save Settings
- Use the SPA9000's web-ui to change Voice tab > Line 3 tab > Contact List: 3335551212:35| [original contact list info]
Enjoy.
<end>
