Alberto Montilla
Analog and ISDN lines monitoring
This application allows monitoring of analog and ISDN lines (DAHDI) in  Asterisk
terrywongkl
Community Member
installed in 2 centos 5 box to test (elastix based asterisk).
in browser only shows image with dahdi channels in red, no status monitored. the clock is running.
apache log file show the followong error,
PHP Notice:  Undefined variable: chon in /var/www/html/monitor_dahdi.php on line 116
any suggestion?
Alberto Montilla
Hi Terry;
Let me check, will get back to you.
Alberto
Alberto Montilla
Here is the suggestion from the expert:
This is happening as your php has enabled the strict mode and any message (error or a warning - your case) stops it execution.
A normal user would have the PHP configuration a bit more flexible, ignoring these messages. However, it is good to be strict, so the script can be solved adding the definition of $chon variable.
Existing code:
   $totalChann=sendcomando($mng,"core show channels");
    for ($t=0; $t<count($totalChann); $t++){
list($chan)=explode(" ",$totalChann[$t]);
list($chan)=explode("-",$chan);
if (strpos($chan,strtoupper($tech)) !== false){
    $chon[]=$chan;
Change it to:
   $chon=array();
    $chon[]=$chan;
Regards;
Alberto
terrywongkl
Community Member
no more error in apache log file. but still, (i have 2 dahdi fxo), only 2 dahdi channel red icon shown, not monitoring.
i have added a user (web) in /etc/asterisk/manager_additional.conf acccordingly, and is shown in asterisk cli. but when i tried,
sip*CLI> manager show connected
user 'web' never shown. is there anything else i can look into it?
