Alberto Montilla
This Application Note describes the configuration of SPA phones (with 6.1 release) to activate the integration of LDAP based corporate directories (such as Microsoft Active Directory 2003 and OpenLDAP), allowing corporate directory contacts search and dial from the SPA9X2 phones.
michelkroon
Community Member
Ok I got it to work. I can search al users and contacts in AD.
Now I have another question.
Is it possible to search in exchange? I would like to create an addresslist thats I can update using Outlook and that I can search using the IP Phone.
Any ideas?
Michel
Patrick Born
Michel,
Thanks for letting me know that you have LDAP working.
No, the phone does not support Exchange.
Patrick
ryan-glenn
Is it possible for SPA9x2 using LDAP to display multiple numbers such as telephone no, mobile no., etc. on a single name?
Ryan
c.hulcher
Yes, you can have the query return multiple items including different phone numbers but only the first attribute that is given the "t=p" tag will be dialable by pushing the "dial" button.
ryan-glenn
Any plans of adding that option in the future? To be able to dial any phone numbers not just one on a particular query.
Ryan
ryan-glenn
I have another question on LDAP. Does SPA9x2 phones support SSL encryption on LDAP? If yes how do we configure the phone for this?
Ryan
Patrick Born
Ryan,
Being able to select from alternate contact numbers and dialing is supported by the SPA525G phone. I've not seen this feature on the SPA9x2 roadmap, but have alerted the phone's product manager.
Patrick
Patrick Born
Ryan,
We're going to release SPA9x2 firmware to support dialing alternate contact numbers. I don't yet have a release date, but it is in the works.
Patrick
radovan.mzik
Community Member
Hello, I would like to ask if there is any progress with firmware which will support dialing multiple contact numbers? One of our customers is asking us for this feature. Many thanks in advance. Radovan
bsd3000it
Community Member
hi Patrick
I have configured the following environment
Several Linksys spa922 with FW version 6.1.5(a).
Asterisk 1.6 Pbx
OpenLdap 2.4
All phones are connected properly to the ldap server.
if I search in the phonebook, I get the correct results from LDAP.
that's great but....
When a call comes in from the outside, the phones do not perform query on ldap so  I see the caller's number on the display NOT the name taken from the ldap
There are any way to get CN in incoming calls?
kind regards
c.hulcher
Manuel,
  Any name information that is displayed on incoming calls from the outside is based on the incoming caller ID information from the phone company.  I don't think that the phone will perform an LDAP lookup for name resolution on calls.
