Update May 09: All of these dialplans are now included by default in CCA release 2.0 and later, so this zip file is not required if you are using that release. The zip file may still be used with CCA 1.9.
The attached zip file contains dialplan plugins for CCA to add support for the following countries:
China
Indonesia
Malaysia
Philippines
Singapore
Taiwan
Thailand
Follow the instructions in the included readme.txt file to apply these dialplans to CCA.
