The Cisco CCA team announces the availability of the latest release of Cisco® Configuration Assistant. Version 3.1.1 is a maintenance release focused on quality improvements. Cisco Configuration Assistant is an easy-to-use interface for managing platforms within the Cisco Smart Business Communications System (SBCS).
Included is also the CCA 3.0 VODS:
https://supportforums.cisco.com/docs/DOC-14425
This announcement covers the following topics:
1. Highlights
2. Documentation
1. Highlights
Software quality improvements that resolve the following caveats:
1. CSCtr84220 - DTMF Mismatch on Existing Cfg Following Changes from Voicemail UI.
2. CSCtr80941 -  CCA: Copyright date needs updating with current year.
2. Documentation
For more information and to download Cisco Configuration Assistant, visit:
http://www.cisco.com/go/configassist
https://supportforums.cisco.com/community/netpro/small-business
Note: Cisco Configuration Assistant 2.x installations cannot be updated to Cisco Configuration Assistant 3.0 and later using the Application Update process. You must download Cisco Configuration Assistant from Cisco.com ( http://www.cisco.com/go/configassist) and install it manually.
For a full list of features supported in Cisco Configuration Assistant and the Cisco SBCS, please refer to the Cisco Smart Business Communications System Feature Reference Guide:
http://www.cisco.com/go/sbcsfeatures
For Cisco Configuration Assistant 3.1.1 release notes, go to:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_configuration_assistant/version3_1/release/Notes/cca_3_1_relnotes.html
An administrator’s guide for Cisco Configuration Assistant 3.1 can be found at:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_configuration_assistant/version3_1/administration_guide/cca_31_sbcs_admin_guide.pdf
Information on Cisco UC500 Software Packs can be found at:
https://supportforums.cisco.com/docs/DOC-9827
You can download the Cisco UC500 Software Pack from the Cisco.com Download Center or from the Support Community at:
https://supportforums.cisco.com/docs/DOC-9829
If you have questions or product feedback, please post them in the Support Community’s CCA FEEDBACK section:
https://supportforums.cisco.com/docs/DOC-12628
To learn more about features in Cisco Configuration Assistant 3.1, please review the Cisco Configuration Assistant 3.1 feature videos posted here:
https://supportforums.cisco.com/docs/DOC-17402
http://www.youtube.com/user/CiscoCCA
Cisco Configuration Assistant 3.1.1 is backward compatible with previous Cisco Configuration Assistant and Cisco UC500 software pack releases.
To learn more about new features in CCA 3.1.1, please review CCA 3.1.1 new feature document posted here:
https://supportforums.cisco.com/docs/DOC-17859
In summary, Cisco Configuration Assistant 3.1.1 maintenance release delivers many quality improvements. The Cisco Configuration Assistant team will continue to develop features and capabilities as we learn more about our customers' needs.
