on 07-11-2017 10:42 PM
Cisco IP Phones have been carefully developed to give you the best experience when using the device. With added lines and softkey functions, a user will now be able to cater to more calls and increase productivity. Communication has been made more collaborative with options such as “Meet Me” and colored LED line functions expand the ways of communicating – amber meaning a user must not be disturbed, or a flashing green indicating that a user has been put on hold.
This article will show you the most common tasks, icons and buttons on your Cisco IP Phone 7800 Series and Cisco IP Phone 8800 Series.
Place a Call |
Go off-hook before or after dialing a number. |
Redial a number |
Press Redial. |
Switch to handset during a call |
Pick up the handset. |
Switch to speaker or headset during a call |
Press |
Mute and un-mute a call |
Press the |
View call history |
Press |
Hold and resume a call |
Press |
Transfer a call to new number |
Press |
Place an intercom call |
Press the Intercom button, then enter a number if necessary. Speak after you hear the tone. |
Start a standard conference call |
Press |
Silence the ring for an incoming call |
Press the Volume button down once. |
Remote line on hold. |
Remote line in use (shared line or line status) |
Incoming call or reverting call. |
Privacy in use, one-way intercom, Do Not Disturb (DND) Active, or logged into a Hunt Group. |
Held Call |
Active call or two-way intercom call. |
All Calls |
Lists all missed, placed, and received calls. |
Answer |
Answer an incoming call. |
Apply |
Confirm a selection. |
Call |
Initiate a call. |
Callback |
Receive notification when a busy extension becomes available. |
Cancel |
Cancel an action or exit a screen without applying changes. |
Clear |
Clear all values. |
Delete |
Delete an entry. |
Del Call |
Delete a call from Call History. |
Details |
Opens the Details for a multiparty call in the Missed, Placed, and Received Call records. |
Dial |
Dial a selected number. |
Divert |
Send or redirect a call to voicemail or to a predetermined phone number. |
Edit |
Modify the highlighted entry. |
EditDial |
Modify a number. |
Exit |
Return to the previous screen. |
Fwd All/Fwd OFF |
Setup/cancel call forwarding. |
GPickup |
Answer a call that is ringing in another group or another line. |
Log Out |
Sign out of Personal Directory. |
Meet Me |
Host a Meet Me conference call. |
Missed |
Open the record of missed calls. |
More |
Display additional softkeys. |
New Call |
Make a new call. |
OK |
OPickup |
Answer a call that is ringing in an associated group. |
Park |
Store a call. |
Play |
Play ringtone or voicemail message. |
PickUp |
Answer a call that is ringing on another phone in your group. |
Redial |
Redial the most recently dialed number. |
Remove |
Remove a conference participant or an entry. |
Save |
Save the chosen settings. |
Search |
Search for a directory listing. |
Select |
Select the highlighted option. |
Set |
Set a ringtone. |
Submit |
Enter user information. |
Swap |
Toggle between two existing calls. |
Update |
Update an entry in Personal Directory. |
Move through entered characters. |
Backspace to delete characters. |
Back. |
Off-hook |
On-hook |
Connected call |
Incoming call |
Missed call |
Received call |
Placed call |
Call on hold/ resume call |
Message waiting |
Shared line in use |
Speed dial line |
Line Status indicator-monitored line is in-use |
Line Status indicator-monitored line is idle |
Line Status indicator-monitored line is ringing |
Line Status indicator-monitored line is in do not disturb (DND) |
Applications |
Contacts |
Messages |
Transfer |
Hold/Resume |
Conference |
Volume -Left: Cisco IP Phone 7800 Series -Right: Cisco IP Phone 8800 Series |
Speakerphone |
Mute |
Headset |
Select button/Navigate across menus and contacts by pressing left, right, up, and down |
End call |
Back/Exit |
