01-01-2018 09:59 PM - edited 03-21-2019 12:49 AM
Article ID:5729
On your switch, all of the routing information is stored in special high-speed memory called Ternary Content Addressable Memory (TCAM) which mainly functions in speeding up route search, packet classification and forwarding, and access control list (ACL)-based commands.
TCAM entries are divided into the following groups:
The Routing Resources page on your switch allows you to adjust the TCAM allocation. Routing resources can be modified incorrectly in one of the following ways:
If you change the router TCAM allocation incorrectly, an error message is displayed. If your router TCAM allocation is feasible, a message is displayed that an automatic reboot will be performed with the new settings.
The following table provides the number of TCAM entries used by the various features:
Logical Entity |
IPv4 |
IPv6 (PCL TCAM) |
IPv6 (Router TCAM) |
IP Neighbor |
1 entry |
1 entry |
4 entries |
IP Address on an interface |
2 entries |
2 entries |
8 entries |
IP Remote Route |
1 entry |
1 entry |
4 entries |
On-Link-Prefix |
N/A |
1 entry |
4 entries |
Note: VLAN mapping uses four TCAM entries in all cases.
This article provides instructions on how to configure the routing resources settings on your switch. In this scenario, the default values must be adjusted in order to accommodate the VLAN mapping routing resources.
Step 1. Log in to the web-based utility of your switch then choose Advanced in the Display Mode drop-down list.
Note: The available menu options, default values, and range values may vary depending on the device model. In this example, SG350X-48MP is used.
Note: If you have an Sx300 Series switch, skip to Step 2.
Step 2. Log in to the web-based utility of the switch then choose Administration > Routing Resources.
The Routing Resources page displays the following:
IPv4 Routing Resources
The Neighbors (1 TCAM entry per neighbor) area displays the following:
Note: There are four TCAM entries per neighbor for the SG550XG series switches and one for the SG350XG series.
The Interfaces (2 TCAM entries per interface) area displays the following:
The Routes (1 TCAM entry per route) area shows the following:
The Total area displays the number of router TCAM entries which are currently being used.
Step 3. In the Maximum Entries area, choose one from the following options:
Important: The sum of new maximum entries of IPv4 Routes + 2* maximum entries of IP Interfaces + maximum entries of IP Host must be at most 992 for Sx350 and SG350X series, and 7424 for Sx550 series. This is the total TCAM entry number minus the number of used non-IP entries.
IPv4 Multicast Routing Resources
The IPv4 Multicast Routes (2 TCAM entries per route) area displays the following:
Step 4. In the Maximum Entries area, choose one from the following options:
IPv4 Policy Based Routing Resources
The IPv4 Policy Based Routes (4 TCAM entries per route) area displays the following:
Step 5. In the Maximum Entries area, choose one from the following options:
IPv6 Routing Resources
The Neighbors (4 TCAM entry per neighbor) area displays the following:
The Interfaces (8 TCAM entries per interface) area displays the following:
The On Link Prefixes (4 TCAM entries per prefix) area shows the following:
The Routes (4 TCAM entry per route) area shows the following:
Step 6. In the Maximum Entries area, choose one from the following options:
IPv6 Multicast Routing Resources
The IPv6 Multicast Routes (8 TCAM entries per route) area displays the following:
Step 7. In the Maximum Entries area, choose one from the following options:
IPv6 Policy Based Routing Resources
The IPv6 Policy Based Routes (4 TCAM entries per route) area displays the following:
Step 8. In the Maximum Entries area, choose one from the following options:
VLAN Mapping Routing Resources
The VLAN Mapping Entries (4 TCAM entries per mapping) area displays the following:
Step 9. In the Maximum Entries area, choose one from the following options:
Step 10. Click Apply.
Step 11. Click OK to proceed.
The switch will automatically reboot to apply the configuration settings to the running configuration file.
You should now have successfully configured the routing resources settings on your switch.
Step 1. Log in to the web-based utility of the switch then choose Administration >Routing Resources.
The TCAM Resources Table displays the number of TCAM entries actually in use and available.
- In Use — Number of TCAM entries utilized for IPv4 routing.
- Maximum — Maximum number of TCAM entries available for IPv4 Routing.
- In Use — Number of TCAM entries utilized for IPv4 Multicast routing.
- Maximum — Maximum number of TCAM entries available for IPv4 Multicast routing.
- In Use — Number of router TCAM entries used for IPv4 Policy-based routing.
- Maximum — Number of available router TCAM entries that can be used for IPv4 Policy-based routing.
- In Use — Number of TCAM entries utilized for IPv6 routing.
- Maximum — Maximum number of TCAM entries available for IPv6 Routing.
- In Use — Number of TCAM entries utilized for IPv6 Multicast routing.
- Maximum — Maximum number of TCAM entries available for IPv6 Multicast routing.
- In Use — Number of router TCAM entries used for IPv6 Policy-based routing.
- Maximum — Number of available router TCAM entries that can be used for IPv6 Policy-based routing.
- Maximum TCAM Entries for Non-IP Rules — Number of TCAM entries available for non-IP rules.
- In Use — Number of TCAM entries utilized for non-IP rules.
- Maximum — Maximum number of TCAM entries available for non-IP rules.
- In Use — Number of VLAN Mapping entries utilized for non-IP rules.
- Maximum — Maximum number of VLAN Mapping entries available for non-IP rules.
Step 2. (Optional) Click the Save button to save the settings to the startup configuration file.
You should now have successfully verified the configured routing resources on your switch.
Note: To learn how to configure the VLAN Mapping settings on your switch, click here.
