Hayfever76
This document will show you how to use the RVS4000 and the WAP4410N together to create both a secure wireless network and a 'Guest' wireless network. The key to making this work is the use of VLAN's and the trunking capability of the RVS.
msoeriksen
Community Member
Thank you for the guide, it helped a lot!
But one thing. If "Inter-VLAN Routing" is enabled then the guest network has access to the main network. Sure, they have to know the IP address, but that's not very secure. I disabled the setting and haven't noticed any problems yet, just the benefit of the guest network being completely isolated.
Can you confirm this or am I misunderstanding something here?
pofarrel
Community Member
This guide does not seem to make sense.  It talks about configuring the WAP, but the only thing mentioned is the RVS?
Hayfever76
Thanks for the comments. I just realized i need to proof my work much better. I'll post an updated version later today that will correct the typos. I'll test the Inter-VLAN routing too. I think you're right about that part Oyvind.
Cheers
John
tloomos
I'm trying to accomplish exactly what is described in this post but not having much luck.  I started by setting up the 2 SSID's and conencting to each - no problems and I was able to get to the internet on both.
Then I tried setting up the VLAN and have run into some problems. My "main" SSID works fine.  When I connect to the guest SSID I'm able to obtain an IP address from the correct range, but I can't get to the internet. This is probably something simple but I just don't know what I'm doing wrong.  Here's my configuration:
RVS4000
Firmware Version: 2.0.2.7
Port 2 connected to WAP4410N
DHCP Enabled on both VLANs
VLAN 1 Local IP: 192.168.1.1
VLAN 4 Local IP: 192.168.4.1
Inter-VLAN Routing: Disabled (**Have tried both Enabled and Disbled with the same results**)
Port 2 Mode: Trunk
VLAN Membership:
     VLAN 1/Port 2: Trunk/Untagged (1untag,4tag)
     VLAN 4/Port 2: Trunk/Tagged (1untag,4tag)
Firewall is setup with out-of-the-box defaults, everything is open. I tried disabling the firewall but received the same results.
WAP4410N
Firmware Version: 2.0.4.2
SSID 1 - default:
     Wireles Isolation: (between SSID): Enabled
     Security Mode: WPA2-Personal
     Wireless Isolation (within SSID): Disabled
     VLAN ID: 1
SSID 2 - guest:
     Security Mode: Disabled
     Wireless Isolation (within SSID): Enabled
     VLAN ID: 4
Any ideas what I'm doing wrong here??
msoeriksen
Community Member
Just to verify, you have two VLANs, one with ID 1 and one with ID 4?
And your WAP4410N is connected to port 2 on RVS4000?
With the exception of using other VLAN IDs (1 and 2 instead of 1 and 4) and a different port (4 instead of 2) my settings match what you have written.
Other VLAN settings I have on WAP4410N is:
VLAN: Enabled
Default VLAN ID: 1
VLAN Tag: Untagged
AP Management VLAN: 1
VLAN Tag over WDS: Disabled
tloomos
Yes, that's correct.  Looks like the other settings match my configuration as well.
Can you confirm that you have the same firmware versions?
RVS4000 Firmware Version: 2.0.2.7
WAP4410N Firmware Version: 2.0.4.2
tloomos
I was able to get this working as desired.
First I tried upgrading firmware on both the router and WAP, but that didn't seem to make any difference.
Then I noticed that when I connected on the guest network, even though I couldn't get to the internet through a browser, Windows networking said I had internet access.  Then I realized that if I tried to get to an internet site by IP address, it worked. I took a closer look at what DHCP was giving me for my IP configuration and noticed I was getting the correct IP address and DHCP server (192.168.4.x) but my DNS server was 192.168.1.1.
On the router I went into LAN settings, switched to VLAN 4 and specfied a static DNS address of 192.168.4.1.  That did the trick.
One other change - I noticed I could still get to "private" network resources from the guest vlan so I went into Advanced Routing and disabled Inter-VLAN routing.
Everything now appears to be working exactly the way I had hoped.
msoeriksen
Community Member
Good to hear you got things working.
Regarding inter-vlan routing it's reassuring that you got the same result as me. Then it isn't just me...
