Factory Reset on PAP2T Phone Adapter using Interactive Voice Response System (IVRS)
Objective
The objective of this document is to reset PAP2T phone adapter to factory default settings. In version 1 of PAP2T there is no hardware reset button on the device. This document explains how IVRS can be used to factory reset PAP2T Phone Adapter.
Applicable Devices
• PAP2T Phone Adapter
Factory Reset PAP2T
Step 1. Connect an analog telephone instrument on any of the phone ports on the PAP2T phone adapter.
Step 2. Dial * four times. The Configuration Menu option is heard as an acknowledgement.
Step 3. Dial a special sequence 73738#. The PAP2T responds with 'Press 1 to confirm or Press * to exit.'. To confirm the factory reset dial 1. This will reset the PAP2T Phone adapter to default factory settings. All the configurations would be reset including all passwords.
