smallbusiness
Community Manager
Community Manager
Article ID:1958
Firmware Upgrade on RV180 and RV180W Using Web Interface
Objectives
This article explains how to upgrade the firmware on the RV180 and RV180W routers. Using the latest firmware helps fix bugs and other intermittent issues on the router.
Applicable Devices
  • RV180
  • RV180W
Software Download URL
RV180
RV180W
Steps of Procedure
Step 1. Use the router Configuration Utility to choose Administration > Firmware Upgrade. The Firmware Upgrade  page opens.
Step 2. In the Firmware Upgrade page,check for the firmware version and the latest available at cisco.com.
Step 3. In the Firmware upgrade page, click Browse.. and navigate to the firmware on the local machine and select the file.
Step 4. (Optional) Check Reset all configuration/ settings to factory defaults to delete all running and saved configurations on the device after the upgrade.
Step 5. Click Start Firmware Upgrade to start. Do not reset or power off the device during the upgrade process.
