08-18-2017 06:23 PM - edited 03-20-2019 11:09 PM
Article ID:5620
The RV340W Dual WAN Gigabit VPN Router with Wireless is part of the RV34x Series and is the wireless counterpart of the RV340. It is easy-to-use, flexible, high-performance, and durable which makes this well suited for small businesses. Now with several added security features such as Web Filtering, Application Control, and IP Source Guard, the RV340W delivers highly secure, broadband, wired and wireless connectivity to small offices and remote employees. These new security features also provide the ease of fine-tuning permitted activity on the network.
This article aims to showcase the features and benefits of the RV340W Dual WAN Gigabit VPN Router with Wireless.
a) b)
c) d)
e) f)
a) RV340W Dual-WAN Gigabit VPN Router with Wireless
b) Ethernet cable
c) Quick Start Guide
d) Power Adapter
e) Console Cable
f) 4 Foam Pads
Parameter |
Default Value |
Username |
cisco |
Password |
cisco |
LAN IP Address |
192.168.1.1 |
Fallback LAN IP |
192.168.1.1 |
Subnetwork Mask |
255.255.255.0 |
The front panel shows the model number, the Reset button and several LEDs for Power, VPN, Diagnostics, LAN, WAN, WLAN, and USB.
Back Panel View
The back panel shows the Wi-Fi button, USB 1 port, WAN ports 1 and 2, LAN ports 1 to 4, console port, On and Off Switch, 12VDC 2.5A power adapter port, and the 4 adjustable external radio antennas.
Right Side Panel View
This LED indicates the status of the device depending on what state it is in.
Function | LED Name | LED Behavior |
LINK/ACT and Speed |
Top LED
LAN1-4
GREEN
GIGABIT |
Bottom LED
LAN1-4
GREEN
Power | PWR |
GREEN
DMZ | DMZ |
GREEN
VPN | VPN LED |
GREEN
Amber
Diagnostic | DIAG |
RED
USB |
USB 1 and USB 2
GREEN
WAN | WAN 1 and WAN 2 |
GREEN
WLAN | 2.4 GHz and 5 GHz |
GREEN
Note: To know more about the product specifications of the RV340W, click here.
As of firmware 1.0.01.17, please be aware of known bug CSCve98765 (https://quickview.cloudapps.cisco.com/quickview/bug/CSCve98765), not shown in the Known Issues anywhere, which renders this router useless for anyone trying to tunnel site-to-site with multiple subnets. You plain can't do it and Cisco have this as a bug of 'moderate' severity, so don't hold your breath.
@Frank McLean I really wish I had seen this BEFORE I purchased it.
