Please generate the necessary XML file for my SIP provider, Bandwidth.com. My email address is jthompson@tcgamerica.com
Parameter | Value
| Comment |
Name of ITSP | Bandwidth.com | Enter name as you would like to see it in CCA drop down, please keep this as short as possible |
Dialplan locale | USA | (optional) provide the country locale if you know this |
Display Proxy Server (Primary) field | 216.82.224.202 | field to enter IP address or DNS of ITSP's primary SIP proxy server |
Display Proxy Server (Backup) field | 216.82.225.202 | (optional) field to enter IP address or DNS of ITSP's backup SIP proxy server |
Display Registrar Server field |
| field to enter IP address or DNS of ITSP's SIP registrar server, this is required if ITSP requires SIP registrations |
Display Outbound Proxy Server field |
| field to enter IP address or DNS of ITSP's Session Border Controller, this is required if ITSP has an SBC that is different compared to its proxy server. |
Display Digest Authentication (Username / Password) | | field to enter username / password for SIP registration or calling, this is required if Registrar Server is present |
Display Customer Company Name field | TCG America, LLC | (optional) choose YES if specific caller name is required for outbound calls, usually ITSP does this |
Display Call Admission Control field |
| (optional) choose YES if ITSP requires the UC500 limit # of SIP calls, usually ITSP does this |
Display User Credentials field |
| (optional) choose YES if ITSP requires SIP registration of all DIDs associated to the UC500 with a unique username / password per DID |
ITSP SIP TRUNK PARAMETERS |
Voice Codec | G.711ulaw, | Choose one of the 3 codecs shown |
Fax protocol | G.711 | Choose one of the 2 methods - T.38 or G.711 upspeed |
RFC2833 (DTMF) payload type | 101 | Default value is 101, if change is required, then enter value in range from 97 to 121 |
Should UC500 register all DIDs to ITSP | No | Typically most ITSPs register only the main number but if all numbers are required then choose YES |
Is SIP registration for DID(s) using same username / password or unique username / password per DID |
| Answer Yes or No only if above row is YES. |
