08-18-2017 08:01 PM - edited 03-21-2019 12:45 AM
Article ID:5464
The Cisco RV130 Multifunction VPN Router with Web Filtering is an easy-to-use, flexible, high-performance device well suited for small businesses. Now with web filtering, the new RV130 delivers highly secure, broadband, and wired connectivity to small offices and remote employees.
This article aims to provide product specifications about the RV130 Multifunction VPN Router with Web Filtering.
Note: To know more about the RV130 Multifunction VPN Router with Web Filtering, click here.
Specifications | Description |
Standards | IEEE, 802.3, 802.3u, 802.1Q (VLAN), 802.1D (Spanning Tree), 802.11i (WPA2 security), 802.11e (wireless QoS), Routing Information Protocol (RIP) v1 (RFC 1058), RIP v2 (RFC 1723), IPv4 (RFC 791), IPv6 (RFC 2460) |
Operating System | Linux |
Cabling Type | Category 5e or better |
Ports | LAN, WAN, USB, Console |
Ports |
4 - 10/100/1000 Mbps Gigabit LAN ports with managed switch, single (1) 10/100/1000 Mbps Gigabit WAN port, 1 USB port, 12VDC power port
Buttons
Buttons | Reset button, Power button |
LEDs | Power, VPN, LAN (1-4), WAN, and USB |
Lock Slot | Slot for Kensington lock |
Physical Specifications | |
Physical dimensions (W x D x H) |
149.86 x 29.9 x 150.11 mm (8.9 x 3.4 x 8.7 in) |
Weight | 0.72 kg (1.6 lb) |
Specifications
Specifications
VLAN Support |
Yes
Network Protocols |
Dynamic Host Configuration Protocol (DHCP) server
Point-to-Point Protocol over Ethernet (PPPoE)
Point-to-Point Tunneling Protocol (PPTP)
DNS proxy
Internet Group Management Protocol (IGMP) proxy and multicast forwarding
Rapid Spanning Tree Protocol (RSTP)
Dynamic Domain Name System (DynDNS), No Internet Protocol (NOIP)
Network Address Translation (NAT), Port Address Translation (PAT)
One-to-one NAT
Port management
Port mirroring
Bonjour
Number of VLANs | 5 active VLANs (3-4096 range) |
Routing Protocols |
Static routing
Dynamic routing
RIP v1 and v2
Inter-VLAN routing
Network Address Translation (NAT) | PAT, Network Address Port Translation (NAPT) protocol |
Network edge (DMZ) | Software-configurable to any LAN IP address |
Spanning tree | Yes |
Load balancing | Yes |
Quality of Service (QoS) |
WAN Queuing
3 queues
Differentiated Services Code Point Support (DSCP)
Class of Service (CoS)
Bandwidth Management for service prioritization
IPv6 |
Dual-stack IPv4 and IPv6
6to4 tunneling
Stateless address auto-configuration
DHCPv6 Server for IPv6 Clients on LAN
DHCPv6 client for WAN connectivity
Internet Control Message Protocol (ICMP) v6
Static IPv6 Routing
Dynamic IPv6 Routing with RIPng
IPv6 host support
IPv6 RADIUS
Network Time Protocol (NTP)
Layer 2 | 802.1Q-based VLANs, 5 active VLANs |
Access control | Yes, management access control list (ACL) plus MAC ACL |
Secure management | HTTPS, username/password complexity |
Firewall |
Stateful Packet Inspection (SPI) firewall, port forwarding and triggering, Denial-of-Service (DoS) prevention, software-based DMZ
DoS attacks prevented: SYN Flood
Echo Storm
ICMP Flood
UDP Flood
TCP Flood
Blocks Java, cookies, active-X, HTTP proxy
Web Filter |
Filters malicious and blocks harmful websites
Application Control |
Yes
IP Source Guard | Bind IP addresses to MAC addresses |
VPN | |
Gateway to Gateway IPsec VPN | 10 gateway-to-gateway IPsec tunnels |
Client-to-Gateway IPsec | 10 client-to-gateway IPsec tunnels using TheGreenBow and ShrewSoft VPN client |
PPTP VPN | 10 maximum tunnels |
VPN Passthrough | IPSec/PPTP/Layer 2 Tunneling Protocol (L2TP) pass-through |
VPN throughput (IPsec) | 50 Mbps |
Web-based utility | Simple, browser-based configuration (HTTP, HTTPS) |
Command-line interface (CLI) | Command line using SSH |
Management protocols | Web browser, Simple Network Management Protocol (SNMP) v3, Bonjour, Universal Plug and Play (UPnP)Yes |
Remote management | Yes |
Event logging | Local, remote syslog, email alerts |
Network diagnostics | Logging, Ping, Traceroute, DNS lookup, and Port Mirror |
Web firmware upgrade | Firmware upgradable through web browser, imported and exported configuration file |
Dynamic Host Configuration Protocol (DHCP) | DHCP Client |
Pv6 host | Yes |
HTTP redirect | Yes |
System time | Supports NTP, daylight savings manual entry |
Languages | GUI support English |
Power | 12V 2.5 A |
Certifications | FCC, CE, IC, Wi-Fi |
Operating temperature | 0° to 40°C (32° to 104°F) |
Storage temperature | -20° to 70°C (-4° to 158°F) |
Operating humidity | 10% to 85% non-condensing |
