08-18-2017 07:03 PM - edited 03-20-2019 11:46 PM
Article ID:5523
The RV345P Dual WAN Gigabit VPN Router with PoE, part of the RV34x Series, is an easy-to-use, flexible, high-performance, and durable router that well suited for small businesses. Now with several added security features such as Web Filtering, Application Control, and IP Source Guard, the new RV345P deliver highly secure, broadband, wired connectivity to small offices and remote employees. These new security features also provide the ease of fine-tuning permitted activity on the network.
The RV345P also comes with eight Power over Ethernet (PoE) ports that are ideal for devices such as Wireless Access Points and IP Phones.
This article aims to provide product specifications about the RV345P Dual WAN VPN Router with PoE.
Note: To know more about the RV345P Dual WAN Gigabit VPN Router with PoE, click here.
Specifications | Description |
Standards | IEEE, 802.3, 802.3u, 802.1D, 802.1p, 802.1X (security authentication), 802.1Q (VLAN), IPv4 (RFC 791), IPv6 (RFC 2460), Routing Information Protocol (RIP) v1 (RFC 1058), RIP v2 (RFC 1723) 802.3af (PoE) |
Operating System | Linux |
Cabling Type | Category 5e or better |
Ports | 16 LAN (8 Data, 8 Power over Ethernet (PoE), WAN, USB, Console |
Ports |
16 10/100/1000 Ethernet, with support for 802.3af
-8 Data Ports
-8 PoE
1 Console port 12V DC 2.5 A power adapter port
2 WAN 2 USB ports |
Buttons | Reset button |
Switch | Power switch |
Lock Slot | Slot for Kensington lock |
Mounting and Physical Security | |
Mounting Options | 2 rack-mount brackets are provided including 8 screws. |
Physical Specifications | |
Physical dimensions (W x D x H) |
280 x 44 x 170 mm (11 x 1.75 x 6.75 in) |
Weight | 1.2 kgs (2.65 lbs) |
Specifications
Specifications
Virtual Local Area Network (VLAN )Support |
Yes
Network Protocols |
Dynamic Host Configuration Protocol (DHCP) server
Point-to-Point Protocol over Ethernet (PPPoE)
Point-to-Point Tunneling Protocol (PPTP)
DNS proxy
Internet Group Management Protocol (IGMP) proxy and multicast forwarding
Dynamic Domain Name System (DynDNS), No Internet Protocol (NOIP)
Network Address Translation (NAT), Port Address Translation (PAT)
One-to-one NAT
Port management
Port mirroring
Bonjour
Number of VLANs | Up to 32 VLANs |
Routing Protocols |
Static routing
Dynamic routing
RIP v1 and v2
Inter-VLAN Routing
Network Address Translation (NAT) | Port Address Translation (PAT), Network Address Port Translation (NAPT) protocol |
Network edge (DMZ) | Software-configurable to any LAN IP address |
Spanning tree | Yes |
Load balancing | Yes |
Quality of Service (QoS) |
Wide Area Network (WAN) Queuing
3 queues
Differentiated Services Code Point Support (DSCP)
Class of Service (CoS)
Bandwidth Management for service prioritization
IPv6 |
Dual-stack IPv4 and IPv6
6 to 4 tunneling
Stateless address auto-configuration
DHCPv6 Server for IPv6 Clients on LAN
DHCPv6 client for WAN connectivity
Internet Control Message Protocol (ICMP) v6
Static IPv6 Routing
Dynamic IPv6 Routing with RIPng
IPv6 host support
IPv6 RADIUS
Network Time Protocol (NTP)
Layer 2 | 802.1Q-based VLANs, 32 active VLANs plus one management VLAN |
Access control | Yes, management access control list (ACL) plus MAC ACL |
Secure management | Hyper Text Transfer Protocol Secured (HTTPS), username/password complexity |
Firewall |
Stateful Packet Inspection (SPI) firewall, port forwarding and triggering, Denial-of-Service (DoS) prevention, software-based DMZ
DoS attacks prevented:
Blocks Java, cookies, active-X, HTTP proxy
Web Filter |
Filters malicious and blocks harmful websites
Content Filter | Static URL blocking or keyword blocking |
Application Control |
Yes
IP Source Guard | Bind IP addresses to MAC addresses |
VPN | |
IPSec | Yes; 50 tunnels maximum, pre-configured profiles for Amazon Virtual Cloud and Microsoft Azure |
Client-to-Site | Yes |
Teleworker VPN Client | Yes |
PPTP VPN |
Yes; 25 maximum tunnels
L2TP Server
Yes; 25 maximum tunnels |
SSL VPN |
Yes; 50 maximum tunnels
VPN throughput (IPSec) | 50 Mbps |
Web-based utility | Simple, browser-based configuration (HTTP, HTTPS) |
Command-line interface (CLI) | Command line using Secure Shell (SSH) |
Management protocols | Web browser, Simple Network Management Protocol (SNMP) v3, Bonjour, Universal Plug and Play (UPnP) |
Remote management | Yes |
Event logging | Local, remote syslog, email alerts |
Network diagnostics | Logging, Ping, Traceroute, DNS lookup, and Port Mirror |
Web firmware upgrade | Firmware upgradable through web browser, imported and exported configuration file |
Dynamic Host Configuration Protocol (DHCP) | DHCP Client |
Pv6 host | Yes |
HTTP redirect | Yes |
System time | Supports Network Time Protocol (NTP), daylight savings manual entry |
Languages | Graphic User Interface (GUI) support English |
Power | 12V 2.5 A |
Certifications | FCC, CE, IC, Wi-Fi |
Operating temperature | 0° to 40°C (32° to 104°F) |
Storage temperature | -20° to 70°C (-4° to 158°F) |
Operating humidity | 10% to 85% non-condensing |
