smallbusiness
Community Manager
Community Manager
Article ID:418
Reboot and Reset Factory Defaults on WAP4410N Wireless-N Access Point
Objective
Reboot is used for maintenance of a device and restarts the device with a saved configuration. The factory default reset is used  to restore the factory default configuration /out-of-box configuration on the device before firmware upgrade and to remove previous configurations made for troubleshooting purposes. It is advised to backup running configuration before you do restart or reboot.
This articles explains how to reboot and reset the factory defaults on a WAP4410N Wireless-N Access Points.
Applicable Devices
• WAP4410N Wireless-N Access Point
Software Version
• 2.0.5.3
There are two ways to reset the Access Point to the factory default configuration.
• Hardware reset
• Reset with the use of the Web-based Utility
Hardware Reset
Step 1. Press the Reset button for approximately ten seconds with a pin located at the back of the device.
Step 2. The Access Point reloads and is set to the default configuration settings.
Step 1. Log in into the web configuration utility page and choose Administration > Factory Default. The Factory Default page opens:
Step 2. To reset the device, click  the Yes radio button to reset the router to the default configuration.
Step 3. Click Save.
A confirm page appears:
Step 4. Click OK to continue with configuration.
Reboot Factory Default
There are two ways to reboot the Access Point.
• Reboot with the use of the Web-based Utility
• Hardware reboot
Reboot with the use of the Web-based utility
Step 1. Log in to the web configuration utility page and choose Administration > Reboot. The Reboot page opens:
Step 2. To reboot the device, click the radio button Yes to reboot the access point from its web-based interface.
Step 3. Click Save to save the set up. Rebooting the device will not cause the device to lose any of the stored configuration.
Hardware Reboot
Step 1. Press the Reset button for less than  eight seconds with a pin located at the back of the device.
Step 2. The Access Point reboots and is refreshed.
