Hello!
I'm trying to get the IPhone / IPad connected to the Router vie VPN cause we're using these devices with custom apps.
The big Problem is, that i get stuck while connection process.
While checking the router log file - I found a couple of errors:
- 2010-10-31 21:29:36: [routerFCAFB6] [IKE] INFO: Configuration found for XXX.XXX.XXX.XXX[27627].
2010-10-31 21:29:36: [routerFCAFB6] [IKE] INFO: Received request for new phase 1 negotiation: XXX.XXX.XXX.XXX[500]<=>XXX.XXX.XXX.XXX[27627]
2010-10-31 21:29:36: [routerFCAFB6] [IKE] INFO: Beginning Identity Protection mode.
2010-10-31 21:29:36: [routerFCAFB6] [IKE] INFO: Received Vendor ID: RFC 3947
2010-10-31 21:29:36: [routerFCAFB6] [IKE] INFO: Received unknown Vendor ID
2010-10-31 21:29:36: [routerFCAFB6] [IKE] INFO: Received Vendor ID: draft-ietf-ipsec-nat-t-ike-02
2010-10-31 21:29:36: [routerFCAFB6] [IKE] INFO: Received Vendor ID: draft-ietf-ipsra-isakmp-xauth-06.txt
2010-10-31 21:29:36: [routerFCAFB6] [IKE] INFO: Received Vendor ID: CISCO-UNITY
2010-10-31 21:29:36: [routerFCAFB6] [IKE] INFO: Received Vendor ID: DPD
2010-10-31 21:29:36: [routerFCAFB6] [IKE] INFO: For 213.162.68.29[27627], Selected NAT-T version: RFC 3947
2010-10-31 21:29:37: [routerFCAFB6] [IKE] INFO: NAT-D payload matches for XXX.XXX.XXX.XXX[500]
2010-10-31 21:29:37: [routerFCAFB6] [IKE] INFO: NAT-D payload does not match for XXX.XXX.XXX.XXX[27627]
2010-10-31 21:29:37: [routerFCAFB6] [IKE] INFO: NAT detected: PEER
2010-10-31 21:29:37: [routerFCAFB6] [IKE] INFO: Floating ports for NAT-T with peerXXX.XXX.XXX.XXX[24682]
2010-10-31 21:29:37: [routerFCAFB6] [IKE] WARNING: Ignore INITIAL-CONTACT notification from XXX.XXX.XXX.XXX[24682] because it is only accepted after phase1.
2010-10-31 21:29:37: [routerFCAFB6] [IKE] INFO: Sending Xauth request to XXX.XXX.XXX.XXX[24682]
2010-10-31 21:29:37: [routerFCAFB6] [IKE] INFO: ISAKMP-SA established for XXX.XXX.XXX.XXX[4500]-XXX.XXX.XXX.XXX[24682] with spi:b75d3xc2bbxxxb2ae5e5:a5b35x1757xxx987b25a
2010-10-31 21:29:38: [routerFCAFB6] [IKE] INFO: Received attribute type "ISAKMP_CFG_REPLY" fromXXX.XXX.XXX.XXX[24682]
2010-10-31 21:29:38: [routerFCAFB6] [IKE] INFO: Login succeeded for user "xxxxxx"
2010-10-31 21:29:38: [routerFCAFB6] [IKE] INFO: Received attribute type "ISAKMP_CFG_REQUEST" from XXX.XXX.XXX.XXX[24682]
2010-10-31 21:29:38: [routerFCAFB6] [IKE] ERROR: Local configuration for XXX.XXX.XXX.XXX[24682] does not have mode config
2010-10-31 21:29:38: [routerFCAFB6] [IKE] WARNING: Ignored attribute 5
2010-10-31 21:29:38: [routerFCAFB6] [IKE] WARNING: Ignored attribute 28678
Does anyone have a hint how to get the connection to work?
Greetings Luke
