cindy toy
Level 7
Level 7
Show ephone registered shows the status of phones that are currently registered to the UC500.  Here, you can find out useful data about each phone.
ephone-1 denotes which ephone in the config is being displayed.
Mac is the MAC address of the phone you have.
TCP socket is the a number used to keep track of which socket belongs to the phone.
activeLine is the number of DN's on the phone that have a call.
UC520#show ephone registered
ephone-1[0] Mac:001D.E5EA.A79E TCP socket:[3] activeLine:2 REGISTERED in SCCP ver 8/8 SPCP ver 1/1
mediaActive:1 offhook:1 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:12
IP:10.1.1.18 18975 CP-524G  keepalive 323 max_line 4
button 1: dn 14 number 205 CH1   HOLD         CH2   IDLE
button 2: dn 16 number 207 CH1   CONNECTED    CH2   IDLE         shared
Preferred Codec: g711ulaw
Active Call on DN 16 chan 1 :207 10.1.1.18 16440 to 10.1.1.14 28370 via 10.1.1.18
G711Ulaw64k  160 bytes no vad
Tx Pkts 754 bytes 120640 Rx Pkts 742 bytes 118720 Lost 0
Jitter 0 Latency 30 callingDn 12 calledDn -1
Username: test Password: 205
ephone-2[1] Mac:D45B.92A8.0000 TCP socket:[6] activeLine:0 REGISTERED in SCCP ver 9/9
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:6
IP:10.1.10.2 40701 SCCP Gateway (AN)  keepalive 16960 max_line 1
port 0/0/0
button 1: dn 5  number 301 CH1   IDLE         CH2   IDLE
Username: anla
