glenn_btn
Hi All
We have recently installed an RV042 in place of a dead Zyxel router. The user has 1 Gigaset sip phone on site which registers. The issue we seem to have is after a who the phone will then show as unregistered and if we reboot the router all is fine again for a while.
I have made sure the firmware is up to date and there is no sip alg option to disable. It's driving me around the bend trying to reolve it. If I can't get this fixed it blows out using this as a replacement for other customers
Any advise here would be great
Glenn
cindy toy
Level 7
Level 7
Hi Glenn_btn,
You created your post as a document instead of a discussion. Please go to the Actions widget on the right column and click on "Create Discussion" and copy over your question.
Cindy
Small Business Community Manager
