Patrick Born
Attached are the XML dictionaries for the SPA30x, SPA50x, and SPA525 phones, v7.4.8
- Danish (dk)
- English (en)
- French (fr)
- German (de)
- Italian (it)
- Dutch (nl)
- Norwegian (no)
- Portuguese (pt)
- Spanish (es)
- Spanish - Mexico (es_mx)
- Swedish (se)
<end>
the_little
Community Member
Bonjour,
Je tente d'utiliser le dictionnaire français pour mon SPA509G mais ça ne fonctionne pas.
Le téléphone télécharge bien le dictionnaire (d'après les logs de mon serveur) mais la langue ne change pas sur le téléphone.
Voici les iformations saisies dans l'interface d'administration, des idées ?
Dictionary Server Script:
Dictionary_Server_Script ua="na" serv=tftp://192.168.1.35/; d0=French;x0=spa50x_30x_fr_v748.xml; / Dictionary_Server_Script
Language Selection: French
Default Character Encoding: UTF-8
Version du firmware (d'après l'interface d'administration) : 7.4.8a
Par avance, merci !
Patrick Born
Hi Leo,
I apologize, I have no command of the French language. <blush>
The syntax described is incorrect. Please refer to https://supportforums.cisco.com/docs/DOC-9952 which describes that d0 and x0 are reserved and can only be used for English as the reference language. This means that you must use syntax similar to the following:
serv=tftp://192.168.1.35/;d1=French;x1=spa50x_30x_fr_v748.xml
I'm busy working on a new feature, dictionaries from the cloud, please try the following:
serv=http://www.ciscosbs2.com/spaDictionaries/spa50x_30x/v746/;d1=French;x1=spa50x_30x_fr_v746.xml
Patrick
Use this reference document to locate SPA phone resources
