smallbusiness
Community Manager
Community Manager
Article ID:404
SPA3102 Firmware Upgrade
Objective
This document guides in performing a  firmware upgrade of SPA3102.
Applicable Devices
This document is applicable to the SPA3102
Software Download URL
SPA3102
Steps for getting a firmware upgrade of SPA3102
Note: Verify the model number and suffix of your SPA3102 VoIP router before you try to update the firmware to ensure that you get the correct file. If the suffix is -NA, proceed with the upgrade. If the suffix is not -NA, the SPA3102 firmware is provided by the VoIP provider, so do not proceed with the upgrade. This is because the SPA3102 configuration settings may be overwritten when the device is upgraded.
The new firmware adds numerous functions to the router. In order to upgrade the firmware of your router, you need to perform two steps: download the firmware and upgrade the firmware of the router.
Downloading the Firmware
1. Before you download the firmware, make sure that your computer has an active Internet connection. If your computer is plugged directly into the router and cannot get online, disconnect your router and plug your computer directly into your cable or DSL modem.
2. SPA3102 firmware is available here: https://www.cisco.com/cisco/software/type.html?mdfid=282414112&i=rm. Registration and login are not required. Cisco recommends that you perform all firmware upgrades on your local network, not remotely.
3. Click Save in the File Download dialog box that appears. Look for the Save As dialog box, choose a location for the file like the Desktop, and click Save. When the download is complete, click Close if prompted.
Note: The name of the file can vary depending on the firmware file of your router.
4. If the firmware file you have downloaded is in zip format, double-click the zip file and extract its contents to a single folder or to the Desktop.
Note: You need to use a utility to open and extract files from the ZIP file archive such as WinZip. In order to download WinZip, visit http://www.winzip.com. You can also use the built-in unzip features of Windows XP to unzip the contents from the archive.
If your SPA3102 was provided by a VoIP provider, request their help to change the firmware version. The provider may have only certified a specific version of SPA3102 firmware for their network.
Once you download the firmware, you need to upgrade the device. For performing the upgrading follow the steps below.
Upgrade the VOIP Gateway Firmware
1. After you extract the file, run the executable file in order to upgrade the firmware
2. When the Firmware Upgrade warning window appears, click Continue.
3. Enter the IP address of the SPA3102 in the field provided.
Note: You can check the IP address of the SPA3102 through the IVR menu. Press ****110# on the analog phone, and press OK. The IVR announced the current IP address of SPA3102.
Make sure the PSTN line is not connected on the FXO port of the SPA3102 while you dial ****110#. The IVR does not work if the PSTN line is connected.
4. The Connecting Status screen appears while it tries to connect to the SPA3102.
5. Once it successfully finds the SPA3102, a window appears that confirms the Firmware Upgrade is successful.
