Alberto Montilla
This documents include the SPA400 Voicemail prompt files for the following languages:
  • Spanish (ES)
  • Italian (IT)
  • Portuguese (PT)
Instructions to upload as well as VM prompts for other languages and versions are available on 2894
jaime.shapiro
Community Member
Hi Alberto, I copied the files in spanish to my usb, and the prompts work in spanish, the problem I have is that are some errors on the way things are being said, let´s say, instead of saying the number seven it says the word "falló" or falied... Please help me solve this problem. Thanks Jaime Shapiro
kristianvilby
Hi Alberto
How do I get hold of the files for danish? I bought all the SPA equipment from a dealer on the internet and they cannot get the files for me.
Best regards, Kristian
pbreedveld
Community Member
Hi Alberto,
I tried to locate the dutch VM prompts at the location you pointed out above:
I can not find the files there, please advise,
Paul
