08-18-2017 06:39 PM - edited 03-20-2019 11:25 PM
Article ID:5179
Specification | Description | |
Standards | IEEE 802.11ac, 802.11n, 802.11g, 802.11b, 802.3af, 802.3u, 802.1X (security authentication), 802.1Q (VLAN), 802.1D (Spanning Tree), 802.11i (WPA2 security), 802.11e (wireless QoS), IPv4 (RFC 791), IPv6 (RFC 2460) | |
Ports | LAN Gigabit Ethernet auto-sensing | |
Cabling Type | Category 5e or better | |
Antennas | Internal antennas optimized for installation on a wall or ceiling | |
LED Indicators | 1 multifunction LED | |
Operating System | Linux | |
Physical Interfaces | ||
Ports | 10/100/1000 Ethernet, with support for 802.3af /at PoE, power port for AC adapter (included) | |
Buttons | Reset button, power on/off push button | |
Lock Slot | Slot for Kensington lock | |
LEDs | 1 LED | |
Physical Specifications | ||
Physical Dimensions (W x D x H) |
5.31 x 5.31x 1.5 in. (135 x 135 x 38 mm) | |
Weight | 0.77 lb or 350 g | |
Network Capabilities | ||
VLAN support | Yes | |
Number of VLANs | 1 management VLAN plus 8 VLANs for SSIDs | |
802.1X supplicant | Yes | |
SSID-to-VLAN mapping | Yes | |
Auto-channel selection | Yes | |
Spanning tree | Yes | |
Load balancing | Yes | |
IPv6 | Yes
Layer 2 | 802.1Q-based VLANs, 8 active VLANs plus 1 management VLAN | |
Security | ||
WPA, WPA2 | Yes, including Enterprise | |
Access control | Yes, management Access Control List (ACL) plus MAC ACL | |
Secure management | HTTPS | |
SSID broadcast | Yes | |
Rogue access point detection | Yes | |
Mounting and Physical Security | ||
Multiple Mounting Options | Desktop or wall | |
Physical Security Lock | Kensington lock slot | |
Quality of Service | ||
QoS | Wi-Fi Multimedia and Traffic Specification (WMM TSPEC), client QoS | |
Performance | ||
Wireless throughput | Up to 1.2 Gbps data rate (real-world throughput will vary) | |
Recommended user support | Up to 64 connective users, 10 active users per radio | |
Multiple-Access Point Management | ||
Single Point Setup | Yes | |
Number of access points per cluster | 4 | |
Active clients per cluster | 120 | |
Configuration | ||
Web user interface | Built-in web user interface for easy browser-based configuration (HTTP, HTTPS) | |
Management | ||
Management protocols | Web browser, Simple Network Management Protocol (SNMP) v3, Bonjour | |
Remote management | Yes | |
Event logging | Local, remote syslog, email alerts | |
Network diagnostics | Logging and packet capture | |
Web firmware upgrade | Firmware upgradable through web browser, imported or exported configuration file | |
Dynamic Host Configuration Protocol (DHCP) | DHCP client | |
IPv6 host | Yes | |
HTTP redirect | Yes | |
Wireless | ||
Frequency | Dual concurrent radios (2.4 and 5 GHz) | |
Radio and Modulation Type | Dual radio, Orthogonal Frequency Division Multiplexing (OFDM) | |
Wireless Local Area Network (WLAN) | 802.11n/ac
2x2 Multiple-Input Multiple-Output (MIMO) with 2 spatial streams at 5 GHz 2x2 MIMO with 2 spatial streams at 2.4 GHz 20-, 40-, and 80 Mhz channels for 802.11ac 20 and 40 Mhz for 802.11n PHY data rate up to 1.2 Gbps 802.11 Dynamic Frequency Selection (DFS) |
Data Rates Supported | 802.11a/b/g:
- 40 MHz bandwidth: MCS 0-15 for supported data rates
- 40 MHz bandwidth: MCS 0-9 for supported data rates - 80 MHz bandwidth: MCS 0-9 for supported data rates |
Frequency Band and Operating Channels | A/B Regulatory Domain
C Regulatory Domain:
Non-overlapping Channels | 2.4 GHz
5 GHz
Wireless Isolation | Wireless isolation between clients | |
External Antennas | None | |
Internal Antennas | Internal Fixed Planar Inverted-F Antenna (PIFA) | |
Antenna Gain in dBi | Maximum antenna gain of 3.61 dBi on 2.4 GHz Maximum antenna gain of 3.85 dBi on 5 GHz | |
Wireless Distribution System (WDS) | Yes | |
Fast Roaming | Yes | |
Multiple SSIDs | 8 | |
Wireless VLAN Map | Yes | |
WLAN Security | Yes | |
Wi-Fi Multimedia (WMM) | Yes, with unscheduled automatic power save |
Operating Modes | ||
Access point | Access point mode, WDS Bridging, Workgroup Bridge mode | |
Environmental | ||
Power Options | IEEE 802.3af Ethernet switch
Cisco Power Injector - SB-PWR-INJ2-xx AC adapter – SB-PWR-12 V/1.5 A power adapter in a box POE power Peak power: 9.5 Watts |
Compliance | Safety:
Operating Temperature | 0° to 40°C (32° to 104°F) | |
Storage Temperature | -20° to 70°C (-4° to 158°F) | |
Operating Humidity | 10% to 85% noncondensing | |
Storage Humidity | 5% to 90% noncondensing | |
System Memory | 256 MB RAM 128 MB flash |
Package Contents | ||
Minimum Requirements | ||
Warranty | ||
Access point | Limited lifetime |
