First, use a ruler to determine the mounting hole positions. The holes should be 3-5/8 inches apart from each other. Mark and drill the holes accordingly.
In this demonstration, we used a 5/32 inch drill bit to drill the holes.
This concludes our tutorial on indoor mounting options for the WAP150. To provide consistent coverage for an indoor location, the WAP150 can be fixed onto a wall within the area. With the appropriate tools and mounting kit, either option can be quickly and easily established.
