Steven DiStefano
CCA 3.0.1 configures Webex Phone connect on UC500!!!
Updated 4/19 thanks to our friend Bob James (see comment below)
bjames
Level 5
Level 5
Steven, a couple of notes; You need DNS configured on the UC for it to connect to Webex (at the login part of the setup). As well if your UC is behind a firewall/ISR I will assume the source IP of traffic is CUE (correct me if I'm wrong) so if this IP range/IP is not in your Firewall/Router NAT list or ACL it will have to be added.
Cheers,
Bob James
Steven DiStefano
All good points Bob.   I update the document.
