Stefano Zanbotti
Community Member
I have a problem with the vpn with the above equipment.
is correct to write here?
mpyhala
Level 7
Level 7
You are in the right place for the WRVS4400N. Please start a new Discussion instead of a Document.
tridelta1
I have a Linksys RVS400n VPN router with firmware version 1.1, and have recently bought a new computer with windows 7 pro 64 bit for a os. I was using windows xp pro which worked fine with the quick vpn client version
1.4.1.2 . I have installed the new quick vpn client 1.4.2.1 on my new computer and cannot seem to get it to work. I hear that it is a windows 7 64 bit problem, and that there might be an update for the quick vpn client to work. I have updated my new computers bios, network drivers. I am not running any antivirus software other than Microsoft Security Essentails and the windows firewall. I have reformatted my new computer since I got it and made the quick vpn client the very 1st thing on the os. Still I cannot get it to work. The error I get is the remote gateway is not responding, do you wish to wait? Any help that you can give me would be great.
