Cisco SF302-08PP + Vivotek SD8362E
spanos001
i have a problem with Cisco switch SF302-08pp.
I try to connect my ip camera Vivotek SD8362E (PoE+) but it doesn't power on at all.
If i try the camera to another PoE switch it works fine.
I tried to change settings on PoE Port setting, but without any luck.
Is there any compatibility issue?
mcselltor
the switch has a PoE+ budget of 62W. Are there other PoE(+) clients connected?
Maybe the PoE budget for the switch is already reached.
Torsten
I tried to disconnect all other PoE devices (3 of them PoE not PoE+) but still Vivotek cam is not power up.
Please check the PoE port settings like
- Port Limit
- Class Power Limit
Is this switch connect to another PoE-switch? It is possible that the switch is powered by another switch due to false detection. To prevent this, PoE should be disabled on uplink ports.
Please have a look at Port Management > PoE > Properties and check the displayed counters.
I disconnected all utp's from switch and left only the Vivotek cam but still no power.
Switch is powered from it's own power supply.
I changed poe port limit to maximum but still nothing.
