07-11-2012 08:07 AM
I use Cisco switch sg300-28. When i turn it off and turn on, it reset to factory reset include login password, dose it normal operation or I miss anything?
Thank you.
Solved! Go to Solution.
07-11-2012 08:30 AM
Hello Jerry, the SX300 series switches have a running configuration and a start up configuration. For the switch to retain settings, you must save the running config to the startup otherwise all settings will be lost.
After making a change there is a blinking save icon on the top right. You may click this and follow the windows. In addition, you can go to Admin -> File Managemenet -> Copy File and save there as well.
07-11-2012 08:30 AM
07-11-2012 10:29 AM
Thank you
