GVRP between SG300 and SG350
Nolaan
I have problem with GVRP between SG300-28 and SG350-28P
Port configuration on SG300
SW-S06-01#show gvrp configuration GE 23
GVRP Feature is currently Enabled on the device.
Maximum VLANs: 4094
Port(s)  GVRP-Status Registration Dynamic VLAN  Timers(milliseconds)
                                    Creation    Join      Leave      Leave All
gi23     Enabled     Normal       Enabled       200       600        10000
SW-S06-01#show running-config interface ge23
interface gigabitethernet23
 gvrp enable
 switchport general acceptable-frame-type tagged-only
 switchport general pvid 4095
 switchport mode general
 switchport general allowed vlan add 100 tagged
On SG350
SW-S06-00#show gvrp configuration GE 25
Maximum VLANs: 4094
gi25     Enabled     Normal       Enabled       200       600        10000
SW-S06-00#show running-config interface GE25
interface GigabitEthernet25
 gvrp enable
The SG350 switch receives information about VLANs, but the SG300 does not get information about VLANs from the SG350 switch
SG350
SW-S06-00#show interfaces status GE1
                                             Flow Link          Back   Mdix
Port     Type         Duplex  Speed Neg      ctrl State       Pressure Mode
gi1      1G-Copper    Full    100   Enabled  Off  Up          Disabled Off
SW-S06-00#show interfaces status GE7
                                             Flow Link          Back   Mdix
gi7      1G-Copper    Full    100   Enabled  Off  Up          Disabled On
SW-S06-00#show running-config interface GE1 , GE7
interface GigabitEthernet1
 gvrp enable
 gvrp vlan-creation-forbid
 gvrp registration-forbid
 switchport access vlan 239
interface GigabitEthernet7
 gvrp enable
 switchport access vlan 236
The SG300 should see additional VLANs 236 and 239, but only see VLAN 100
SW-S06-01#show interfaces switchport GE 23
Added by: D-Default, S-Static, G-GVRP, R-Radius Assigned VLAN, T-Guest VLAN, V-Voice VLAN
Port : gi23
Port Mode: General
Gvrp Status: enabled
Ingress Filtering: true
Acceptable Frame Type: admitOnlyVlanTagged
Ingress UnTagged VLAN ( NATIVE ): 4095
Port is member in:
Vlan               Name               Egress rule     Added by
100           ManagementVLAN            Tagged           S
Forbidden VLANS:
Vlan               Name
Classification rules:
Mac based VLANs:
  Group ID   Vlan ID
SG350
SW-S06-00#show version
Active-image: flash://system/images/image_tesla_hybrid_2.5.0.90_release_cisco_signed.bin
  Version: 2.5.0.90
  MD5 Digest: a3518dae9be5eaba8ffd726de14367fa
  Date: 26-Sep-2019
  Time: 16:18:10
Inactive-image: flash://system/images/image1.bin
  Version: 2.4.0.94
  MD5 Digest: 6f5be217100f34929986f2e93dd2d5e9
  Date: 31-May-2018
  Time: 02:39:58
SG300
SW-S06-01#show version
SW version    1.4.10.6 ( date  16-Apr-2019 time  18:35:56 )
Boot version    1.3.5.06 ( date  21-Jul-2013 time  15:12:10 )
HW version    V02
Also tested with SF300-24P  (SW version 1.4.11.2) and does not work with SG350
0 Replies 0
