10-06-2015 01:00 PM
Are there any documents available from Cisco that would help configure SF302-08PP and other similar switches for use solely with IP Cameras.
I would like to configure these switches for maximum performance with very high end 5 mp ip cameras.
I notice there is some configuration under the SmartPort but not real specific on what needs to be done to optimize.
10-07-2015 03:32 AM
10-07-2015 12:46 PM
Hello arunhassan9081,
A couple questions, is the security system the only devices on VLAN600? What is doing the routing between VLANs in your network? Depending upon how the routing is being done, you may have to setup ACLs that deny traffic to and from VLAN600 network if the general users are in a different VLAN. A little more information would be needed such as the topology and VLAN scheme being implemented to give a definitive answer. But more than likely, the device doing the routing is where the security would be applied.
10-07-2015 12:39 PM
Hello DRackley6922,
I have found this link that may be helpful in optimizing the video traffic in your network.
https://supportforums.cisco.com/document/141056/smarttipsswitchsgsf300-qos-englishpdf
