03-26-2020 08:07 AM
ir1101#reload
Proceed with reload? [confirm]^S
ir1101#reload
ir1101#reload
ir1101#
ir1101#reload
ir1101#reload
ir1101#
It looks like ^S is appended and it blocks actual reload.
not sure if its a bug or there is config problem.
03-26-2020 08:39 AM
- Check sanity of your current terminal-operator equipment, possibly try another solution to access the device, check if the problem persists.
M.
03-26-2020 02:37 PM
