Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2994 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4588 Views
  • 1 replies
  • 16 Helpful votes
Hi BackgroundI have setup an SG300-28 as a layer 2 switch with multiple VLANs.There are the following VLANS1DefaultEnabledEnabled100BT ADSL+ FirewalledStaticEnabledEnabled200Virgin Fibre FirewalledStaticEnabledEnabled300Tardis Backup LANStaticEnabled...
Hi.I didnt think I was such a newbie until I watched this Cisco Tech Talk video Cisco Tech Talk: Segmenting Your Switch Using Multiple VLANs My understanding was that to keep isolation between a handful of different subnets on one of our switches, I ...
Hi Guys,I have a question about acl and vlan interface.I create test environment as follow: Cisco SG300 in Layer 3 ModeVlan: 1IP interface: 172.16.1.2/30"This is transit network to pfsense" Vlan: 200IP interface: 192.168.100.0/24"This is clients VLAN...
chiprule by Level 1
  • 1508 Views
  • 4 replies
just had a switch fail to boot and it appears the firmware is corrupted, is there anyone out there by chance has a copy of the 1.2.2b or something similar so i can revise this switch? I have found some older firmware but they are unsupported or are c...
Dracarys by Level 1
  • 807 Views
  • 1 replies
On both SG200 26P and SG300 and 28P switch web UIs I have been having this issue. When trying to utilise download or backup to a tftp server I keep getting this: Error Message: Abort from tftp serverThis has happened on different versions of the firm...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
