Rogue Hub/Switch blocking?
brett1042002
I've noticed MAC addresses with a 0000.0000.0000 on some of our switch ports in a particular building.  It turns out some end-users were plugging in personal/unauthorized hubs and/or cheap 5-port switches into our network on those interfaces.  We manually disabled the ports, then sure enough the end-users called the helpdesk informing us they lost network connectivity.
Portfast and BPDU guard is enabled all edge devices.  However, since these are cheap hubs and switches I don't think they are even doing STP.  So having BPDU guard err-disable the port isn't our fix.
So, is there another way to block these devices?  ACL?  MAC filtering?  Can you just block MAC 0000.0000.0000?  Maybe someone can explain what MAC 0000.0000.0000 means?
I'm aware of port security, and that is in the works currently, but was hoping for a quick fix in the meantime.
Thanks!
-Brett
Tom Watts
Depending what kind of switch you have, you may have dynamic arp inspection, where you register only trust mac on the switch database and the switch will discard any other mac connecting. Port security is another option, allow a max of 1 mac on the port, but the problem will persist that if connect a hub + computers, the port will get shut down and you have to reactive the suspended port each time.
Here is also a good post to review for an ACL
https://supportforums.cisco.com/message/3727181#3727181
-Tom
Please rate helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Tom Watts
-Tom
Ah, I will look into dynamic arp inspection.  Thanks!
Yea, we are currently testing/implementing port security, sticky MAC, and 802.1x for workstation authentication.
Tom,
I was reading that link on class-maps.  Does that only apply to individual interfaces on the switch?  Would a class-map work in my scenario?
class-map MACDENIED
match source-address mac xxxx.xxxx.xxxx
policy-map MACDENIED
class MACDENIED
drop
interface x/x
service-policy input MACDENIED
