04-12-2013 09:03 AM
First of all, is there a document on the SG300 that explains everything in plain english?
Here is what I am trying to do...
I have a Charter Communications connection to the internet through their modem.
This modem has a static IP.
I would like to make this internet connection the source for the SG300 and all the other ports be DHCP.
I was told when I purchased it that being a layer 3 device, it would do it.
Thanks for any help in advance.
-Roger
04-12-2013 09:53 AM
Hi Roger, the only problem with this is the fact the switch cannot NAT, therefore this will not work unless you have a public IP from Charter for every connecting device.
-Tom
Please mark answered for helpful posts
04-12-2013 10:03 AM
So should I connect the charter modem, which is one public IP, to a router and then to the SG300?
04-12-2013 12:41 PM
Yes, you'd need a router that does NAT then connect the switch to that other router.
-Tom
