09-11-2017 04:27 AM - edited 03-21-2019 11:15 AM
Read some of the threads regarding this issue, but seems like the context has been changed over time.
I can't get it to work, at the moment I removed the ip helper lines, since I couldnt get option 67 and 68 to work, only 37, 138 and 139.
So this is the running config for now, any suggestions how to get it working?
TND-SITE-SW-1#show run config-file-header TND-SITE-SW-1 v1.4.2.4 / R800_NIK_1_4_194_194 CLI v1.0 set system mode router file SSD indicator encrypted @ ssd-control-start ssd config ssd file passphrase control unrestricted no ssd file integrity control ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0 ! no spanning-tree spanning-tree mode mst vlan database vlan 200 exit voice vlan oui-table add 0001e3 Siemens_AG_phone________ voice vlan oui-table add 00036b Cisco_phone_____________ voice vlan oui-table add 00096e Avaya___________________ voice vlan oui-table add 000fe2 H3C_Aolynk______________ voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone voice vlan oui-table add 00d01e Pingtel_phone___________ voice vlan oui-table add 00e075 Polycom/Veritel_phone___ voice vlan oui-table add 00e0bb 3Com_phone______________ ip dhcp relay address 10.180.21.20 ip dhcp relay address 10.180.21.21 ip dhcp relay address 10.180.21.27 ip dhcp relay enable ip dhcp information option bonjour interface range vlan 1 ip access-list extended 1 exit hostname TND-SITE-SW-1 enable password level 15 encrypted 94347e2bb2e89e334a91cff78e478f0b9cc1e2f3 username cisco password encrypted 94347e2bb2e89e334a91cff78e478f0b9cc1e2f3 privilege 15 snmp-server community public ro view Default snmp-server host 76.67.196.17 traps version 1 public ! interface vlan 1 ip address 172.16.40.86 255.255.255.248 no ip address dhcp ! interface vlan 200 name Prod ip address 10.180.212.1 255.255.255.128 ip dhcp relay enable ! interface gigabitethernet1 spanning-tree portfast switchport mode access switchport access vlan 200 ! interface gigabitethernet2 spanning-tree portfast switchport mode access switchport access vlan 200 ! interface gigabitethernet3 spanning-tree portfast switchport mode access switchport access vlan 200 ! interface gigabitethernet4 spanning-tree portfast switchport mode access switchport access vlan 200 ! interface gigabitethernet5 spanning-tree portfast switchport mode access switchport access vlan 200 ! interface gigabitethernet6 spanning-tree portfast switchport mode access switchport access vlan 200 ! interface gigabitethernet7 spanning-tree portfast switchport mode access switchport access vlan 200 ! interface gigabitethernet8 spanning-tree portfast switchport mode access switchport access vlan 200 ! interface gigabitethernet9 ip dhcp relay enable spanning-tree portfast switchport mode access switchport access vlan 200 ! interface gigabitethernet10 description "*** TND-SITE-RO-1 ***" spanning-tree portfast switchport mode access ! interface gigabitethernet11 spanning-tree portfast switchport mode access switchport access vlan 200 ! interface gigabitethernet12 spanning-tree portfast switchport mode access switchport access vlan 200 ! interface gigabitethernet13 spanning-tree portfast switchport mode access switchport access vlan 200 ! interface gigabitethernet14 spanning-tree portfast switchport mode access switchport access vlan 200 ! interface gigabitethernet15 spanning-tree portfast switchport mode access switchport access vlan 200 ! interface gigabitethernet16 spanning-tree portfast switchport mode access switchport access vlan 200 ! interface gigabitethernet17 spanning-tree portfast switchport mode access switchport access vlan 200 ! interface gigabitethernet18 spanning-tree portfast switchport mode access switchport access vlan 200 ! interface gigabitethernet19 spanning-tree portfast switchport mode access switchport access vlan 200 ! interface gigabitethernet20 spanning-tree portfast switchport mode access switchport access vlan 200 ! interface gigabitethernet21 spanning-tree portfast switchport mode access switchport access vlan 200 ! interface gigabitethernet22 spanning-tree portfast switchport mode access switchport access vlan 200 ! interface gigabitethernet23 spanning-tree portfast switchport mode access switchport access vlan 200 ! interface gigabitethernet24 spanning-tree portfast switchport mode access switchport access vlan 200 ! interface gigabitethernet25 spanning-tree portfast switchport mode access switchport access vlan 200 ! interface gigabitethernet26 spanning-tree portfast switchport mode access switchport access vlan 200 ! interface gigabitethernet27 spanning-tree portfast switchport mode access switchport access vlan 200 ! interface gigabitethernet28 spanning-tree portfast switchport mode access switchport access vlan 200 ! exit ip default-gateway 172.16.40.81
09-11-2017 07:07 AM
