SG500-52 Stack weird saving issue
Alasdair Clark
I've inherited a 3 unit stack that displays the following symptoms:-
When i login to the GUI, i am taken to the getting started page , even though i have ticked the "do not  show this page on startup" box & saved the config.
Occasionally, the save icon will flash , even though no changes have been made
Any ideas ?
Aleksandra Dargiel
Hi Alasair.
Yes, I believe it was seen before with old firmware so the first thing you need to do to get the latest firmware and boot code as well.
If you tell me on which version you are now I would give you some steps how to proceed with steps upgrade as might be needed.
Aleksandra
Hi Aleksandra
Thanks for the reply, below are the version currently running on the stack
Firmware Version (Active Image): 1.4.8.6
Boot Version: 1.4.0.02
Many Thanks
Alasdair
Hello Alasdair,
Sorry for late response. If this issue still bothers you I suggest to open ticket with support team so they can verify everything. It has not been reported since long time so we need to see what is happening.
Aleksandra
