08-26-2019 08:12 AM
I have a SG500 and am looking to seperate out my network from a current flat network. I want to have 5 vlans with one being a DMZ. I have a dynamic internet connection that most vlans will need to connect to. I have a firewall hainging off the side that I want most internet traffic to go through. I have two Aruba AIP 215's that will trunk three vlans. I want my managment vlan to be accessable by a few computers on another vlan for admin purposes. I also need access to a media server via 2 of the vlans. Below is a small list and what I'm wanting to do. I'm having a hard time wrapping my head around how to set this up. Below is my devices:
vlan10: Managment 192.168.10.0/24
vlan20: LAN/clients 192.168.20.0/24
vlan30: DMZ 192.168.30.0/24
vlan40: VPN 192.168.40.0/24
vlan50: IoT-Devices 192.168.50.0/24
ge1/0/1 - Cable Modem ISP Dynamic IP - Internet
ge1/0/2 - vlan10/20/30/40/50 - Media Server / Firewall (Untangle) / VPN
ge1/0/3 - vlan10 - NAS Media Storage
ge1/0/4 -POE - vlan20/30/50 -Aruba AIP 215 WiFi
ge1/0/5 -POE - vlan20/30/50 -Aruba AIP 215 WiFi
ge1/0/28 - vlan20 - PC
ge1/0/27 - vlan20/40 - PC
As I mentioned all but vlan10 need to be able to access to internet. I need to be able to access servers on vlan10 from vlan 20. I need to be able to use the vpn from several servers as well as my main PC. I will have a IoT vlan that will access the internet but I want it completely seperated from the rest of the network. It will connect to Home Assissant that will be centeral controler for all the IoT devices. Is it also possible to have a backup route for incase the firewall goes down? If so I would only want to allow TCP443 and UDP 53 so I can at least have connectivity in the event the server housing the FW goes down. Any help given will be greatly appreaciated.
I'm really unsure how to route all the traffic through the FW if I have it off the side instead of inline as it currently is. Right now I go (Cable modem - FW - Switch - Network) and I have the FW handling the NAT and DHCP. I want the switch to handle NAT and DHCP but pass all outbound traffic to the FW first. Thank you.
- Jeremiah
08-26-2019 08:51 AM
Hi Jeremiah,
This might be a little elementary for you, but thought I'd send it over anyway. This is a getting started video for Inter-VLAN routing: https://www.youtube.com/watch?v=xK5HmMlaIlg
