Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3053 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4629 Views
  • 1 replies
  • 16 Helpful votes
I have a network with 3x SG300-52p switches and 3x SG300-28PP switches.  All are set as L3 even though I only wound up using them as L2.  I have a VPN set up in my firewall and I'm able to connect in.  From my VPN connection I'm able to connect to th...
StewJo by Level 1
  • 1852 Views
  • 4 replies
Hi, I am hoping someone can help me with an issue i have with our printers and Cisco SG500 switches. We use MAB authentication on the switch ports along with dynamic VLAN assignment for the devices. The problems is when the printers go to sleep the p...
atemple by Level 1
  • 454 Views
  • 0 replies
Folks  I m super frustrated. i thought by getting the cisco RV340 router  it will solve my problem by allowing me to create a static NAT for my private vLANs to access internet.when connecting the RV340 router i got my ISP IP and created the needed v...
VMwareLab by Level 1
  • 3163 Views
  • 3 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
