office@c-bit.hr
I was buy brand new router and have connected him to console port but when i need to hit enter after I get message press enter
.I push enter but it says: " authentication error"
I see there is some errors during startup in IOS row 1,5,6,7,8 is little strange to see errors on brand new router.
If is there solution for my problem I will be thankful for it .
regards
Kristijan
balaji.bandi
Since it is new router, you can power cycle and configure back from the beginning ?
or Look for factory reset from cisco documentation :
https://dcloud-cms.cisco.com/help/reset-router
or
https://www.cisco.com/c/en/us/td/docs/routers/access/4400/troubleshooting/guide/isr4400trbl/isr4400trbl02.html
Leo Laohoo
Console into the router and post the complete bootup process. We want to see what the router is doing. Try the username/password of "Cisco/Cisco".
Irfan1070
Cisco Router 4331 I Need cad drawings..
if you by mistake run aaa new-model and  reboot before add username/password then you need factory set
