Resend security token
vbgetronics
Is it possible to get security token again?
Basically, callhome was configured with wrong email address. So, didn't get the token required for registering the device. Is it possible to generate it again or request for it to be sent again?
Lawrence Searcy
Sorry, my last information was incorrect and I deleted the response to avoid confusion in the future.
Smart Call Home will send a new registration email with each INVENTORY message it receives. I verified this in the lab after a co-worker mentioned it should work this way.
After correcting the email address on the end device, on the nexus you can use the command
callhome test inventory
on IOS, use the command
call-home send alert-group inventory profile CiscoTAC-1
Lawrence Searcy
You are correct. I got the registration email again after changing the email address. Thank you very much.
