Smart Call Home
Our online forum for Smart Call Home customers to share, learn, and collaborate on Smart Call Home related topics.
Welcome to the Smart Call Home Community!
Our online forum for Smart Call Home customers to share, learn, and collaborate on Smart Call Home related topics. We encourage you to ask questions of Cisco experts, start a discussion, or share ideas and insight.
Smart Call Home enabled devices perform proactive diagnostics on their own components to provide real-time alerts and remediation advice when an issue is detected. An embedded support feature available on a broad range of Cisco products, it is provided at no additional cost with an active Smart Net Total Care Service, SP Base, Unified Computing Support Service, or Mission Critical Support Service contract for the designated products.
This Community will provide you with an overview about Cisco Smart Call Home features and how these features are embedded in a wide range of Cisco products to help your network. Smart Call Home provides higher network availability and support service quality.
Smart Call Home System Maintenance
Thank you for your patience while the Smart Call Home portal was temporarily unavailable, while we performed maintenance. All systems are now operating normally. If you experience any further issues, please let us know.
To begin using Smart Call Home:
1. Are you ready? Find out! Use the new SCH Readiness Check Tool!
2. Check to see that your devices are supported by Smart Call Home.
3. Review the customer or partner preliminary checklist and the Deployment Guide.
4. Go to the appropriate Quick Start Guide for your product(s) and configure your devices.
5. Register your devices on the Smart Call Home portal.
6. For help with registration, contact Cisco Worldwide Support, available globally during local business hours.
Smart Call Home Technical Resources
Release and General Information
Smart Call Home and Transport Gateway (TG) Release Notes
Smart Call Home Security White Paper
Smart Call Home Frequently Asked Questions (FAQ)
Smart Call Home Supported Products
Smart Call Home Portal
ASA Smart Call Home common uses and periodic monitoring is a great resource for information on configuring your ASA to use Smart Call Home.
Reference Guides
Smart Call Home User Guide
Smart Call Home User Guide for Partners
Install and Upgrade Guides
Troubleshooting and Support
Smart Call Home Monitoring Details
Download SCH Configuration Script
Download SCH Certificate Upgrade Script
Cisco Server Security Certificate
Smart Call Home Transport Gateway Technical Resources
Transport Gateway (TG) Load Balancing White Paper
Transport Gateway Frequently Asked Questions (FAQ)
Deploying TG on Cisco Unified Computing System and Red Hat Linux
Deploying TG in a Load-Balanced Environment
Install Guides
Transport Gateway Installation and Configuration
Software Downloads
Download the Transport Gateway Software
Activity in Smart Call Home
SSM On-Prem 8 upgrade
Hi,we are using a SSM On-Prem satellite server to manage the Smart Licenses on our network.I want to upgrade our 8.202008 to 8.202105 so I follow the instructions from the "SSM On-Prem 8 Installation Guide". So I connect to the SSM server over ssh (P...
thierry68 by Level 1
  • 6985 Views
  • 9 replies
Call-Home SSL errors
Hi Everybody! I'm new to the field and new to my current place of work and that place of work is new to everything related to smart licensing, smart call-home, etc. Nobody here has touched IOS-XR until a month ago also. I am almost CCNA RS level know...
Resolved! On Prem SSM does not register devices
I have been struggling with getting my switches to properly register with my on prem SSM.  I have followed every guide I can find, as well as looking at solutions on this board, all with no results.  I have been able to use the SSM with my DNAC and I...
Resolved! Smart Licensing URL
Hoping someone might be able to help clarify the proper URL for smart licensing registration on ISR 4K routers and 9200L switches.I've seen different things on different documents.  For example, some documents make reference to "smartreceiver.cisco.c...
Unable to register Cloud Services
Hello FPR1010 FDM and trying to register device for smart services, which tells me I need to register for cloud services. I try and do this but get "Failed to resolve cloud service FQDN. Check network connectivity or DNS configuration and retry." On ...
TheGoob by VIP
  • 1144 Views
  • 5 replies
Lost Base license of ASA 5516-X FTD
Hi, my company have a device ASA 5516-X Threat Defense (75) Version 6.2.3 (Build 83) that purchased since 2017. Now I have to reconfigure the firewall but I found that the base license lost. I try to contact with supplier but they quit, so how can I ...
Resolved! CONNECT_FAILED(35) to satellite server
I am trying to register an ASAv via my Satellite server but when I test the smart call home profile via CLI to my satellite server I get this message. call-home test profile LicenseINFO: Sending test message to https://F.Q.D.N/Transportgateway/servic...
kjp1231 by Level 1
  • 6361 Views
  • 6 replies
