CSPC 2.9 configuring your CSPC appliance failed
jeroenm17
when configuring the new CSPC 2.9 collector, it failed when configuring a static ip or a ip via DHCP.
Please select from the below options:
1. Get IPv4 Address automatically (Use DHCP)
2. Enter IPv4 Address manually (static IP Address)
3. Main Menu
Enter your choice : 2
Enter IP Address : xxx.xxx.xxx.xxx
Enter Net Mask : xxx.xxx.xxx.xxx
Enter Default Gateway : xxx.xxx.xxx.xxx
Configuring your CSPC appliance...
Connection successfully activated (D-Bus active path: /org/freedesktop/NetworkManager/Activeconnection/2)
Failed!
Press [Enter] key to continue
When we use option 1 we only see;
Failed!
Does anyone have seen this error before? we already had a CSPC running in the environment.
gausing5
I am looking into the issue and will get back to you with the updates.
Gaurav Singh
Sorry, this has allready been solved.
I am experiencing the same issue.  What was the solution you used to resolve this issue?
The CSPC VM was assigned to a wrong network, due to this is was unable i guess to ping to cisco.
