Run upload Profile error HTTP Status 500
Running upload profile and received the above error on the collector.
8 Replies 8
CC Cisco
Please share the appliance ID as well as the following log files for analysis.
/opt/ConcsoTgw/tail-end-gateway-decoupled/bin/nohup.out
/opt/ConcsoTgw/tail-end-gateway-decoupled/bin/CONN_TEG_LOGS/tail-end-gateway.log
Hi Enzo,
If you still need assistance, please private message Cesar the following:
If this issue is resolved, please mark accept as solution to close the discussion.
Thanks!
Cheri
Customer replied to me that he was unable to access those logs. Can you send the exact instructions on how to access those logs.
Hi Enzo,
These logs should be accessible via CLI with root privileges.
Make sure to enable the additional CLI user access.
In addition, if you can provide the appliance ID, we can investigate further.
Thanks for the information shared via PM. To "read" the log files you can use the cat command. For example:
cat /opt/ConcsoTgw/tail-end-gateway-decoupled/bin/nohup.out
cat /opt/ConcsoTgw/tail-end-gateway-decoupled/bin/CONN_TEG_LOGS/tail-end-gateway.log
To extract the file, you can look into an utility such as WinSCP.
In addition, can you try the following:
* Re-apply the certificate on the web UI and share the screenshot of whether the license applies successfully or not?
Cesar
Here are the log files requested
Can  you send the instructions on how to reapply the cert
The option is under: Help -> About -> View Properties -> License Properties
