12-07-2018 02:10 AM
Hello
For SNTC polls CSPC once a month.
Is it possible to poll it every 2 weeks ?
thanks
JM
Solved! Go to Solution.
12-07-2018 04:25 AM - edited 12-07-2018 04:27 AM
You should be able to do so if you manage your own CSPC appliance.
If you navigate to Settings >> Manage Data Collection Profiles:
you should be able to drill into the monthly job you run (in this example, the job is called SmartNet_Upload), right-click it, and select "Modify Collection Profile":
Once up, you'll see three tabs. The "Profiles Details" will be where we need to do this change:
From here, scroll down to the "Collection Profile Schedule" section. It is here that you can drill into the "Configure Schedule" window:
The option that you are seeking (Recurrence Pattern) will appear in the bottom half of this window. Once you select "weekly", you can set the schedule to run every two weeks as requested:
For the Upload portion, navigate to Settings >> Manage Upload Profiles and run the same set of steps.
12-07-2018 04:32 AM
12-07-2018 04:32 AM
